Maintenance & Repair Care and feeding of your rig
Removing Locking Lugnuts - Without the Key
Old 06-05-2006, 05:08 PM
DoubleZero4x4's Avatar
Removing Locking Lugnuts Without the Key
By DoubleZero4x4
This idea came from a Corvette owner:
You need to get a 12 point socket that barely fits and drive it on tightly, 4-5 decent wacks with a ball pean hammer will do the trick. You have to make sure the slots in the socket bite into the lug nut. Use a manual lug wrench - not a pneumatic tool to loosen the lug. Slow even torque is the ticket. When loose the lug will be stuck tightly in the socket. Place socket in a vice and drive ilug nut out with a drift punch and repeat three more times. Then throw the stupid locks away and get some standard lugs from the dealer in town.
I can tell you that it worked!!! I pounded on a 19mm socket and used a breaker bar to turn it slowly. Worked like a charm. Once the locking lugs were loose I simply pulled up and down slightly so that the socket would loosen up on the lug. Went to the stealership and picked up 4 news lug nuts and tossed the locking ones.
okamikai
04-30-2018 10:19 PM
TDonkey
07-26-2015 10:14 AM
RustBucket
07-24-2015 04:46 AM
Hamonacracker
07-17-2015 08:33 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Removing Locking Lugnuts - Without the Key
