will my truck last threw duck hunting
Old Aug 20, 2007 | 10:28 PM
90inworks's Avatar
well early goose season is starting up on sept 8th for a week (19 days (im not counting)..) My truck will be LOADED down ill be hauling my 14' smokercraft with a 15hp merc. Plus 2 dogs guns and decoys..... The poor truck will be strugling any good tips to keep my motor from going? Oil change? any thing helps... any one else getin ready for the season?????
Old Aug 20, 2007 | 10:33 PM
the_gunslinger's Avatar
if it needs some attention, give it what it needs. new transmission fluid and filter might not hurt... if it burns oil, a set of spark plugs might keep you from getting stranded...
Old Aug 20, 2007 | 10:34 PM
stormin94's Avatar
Make sure you got plenty of oil, and gas.....and ammo.
Old Aug 20, 2007 | 11:11 PM
Jay351's Avatar
fresh anti freeze, fresh oil.
check your diff levels..
carry extra coolant and oil just incase!
Old Aug 21, 2007 | 02:44 PM
Adam F's Avatar
Get a $70 set of air shocks to help level out the load in the rear.
Old Aug 21, 2007 | 11:03 PM
90inworks's Avatar
well i changed the oil tonight (made a mess of the garage floor)
slaped a new air filter in
no need for new shocks i put 2in lift blocks in the rear
my truck does pretty crappy towin the boat so i cant wait to see how bad its gonna suck when its loaded down
Old Aug 21, 2007 | 11:19 PM
CyMoN's Avatar
and a new tstat and test it before you put it in
Old Aug 24, 2007 | 01:45 PM
Adam F's Avatar
The air shocks will level the truck out when loaded. You add air to them and it will bring the truck up. You say your going to throw a bunch of junk in the back of the truck and tow a boat. Your rig will be squatting pretty good in the back. Put the air shocks on and you can get rid of the sag.
And with all that weight back there, running blocks is BAAAAD. BAAAAAAAAAD I tell you. I had a set and they BOTH split down the middle. Tilted the pinion up, ripped the drive shaft out of the truck, and the axle was cocked to the side since there was now a 2" gap between the ubolts and the axle. It bent the entire drive shaft so I had to replace it. That was without towing anything.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
87blyota
Jul 1, 2015 05:26 PM
mtnbkr
19
Aug 6, 2002 03:55 PM
