Wheel Question
Old Mar 10, 2007 | 06:27 PM
Elvota's Avatar
Wheel Question
Anyone know how wide a tire I can run on a 8" rim?
I'd like to mount some 35x12.5" Goodyear MTR's on a factory alloy Toyota rim which happens to be 15x8". I have 15x10" steel rims now which work.
Anyone happen to be running a setup like this?
Old Mar 10, 2007 | 06:28 PM
olharleyman's Avatar
I'm running 35 x 12.5 on a 8" rim
Old Mar 10, 2007 | 06:39 PM
d0ubledown's Avatar
im on 12.5 on an 8" rim. general rule of thumb/guidline is not to exceed 4-4.5" of wider tire than rim. doesnt mean its not doable...its just a bit more bubbly the narrower wheel you go.
Old Mar 10, 2007 | 07:04 PM
AlaskaToy's Avatar
not a problem. run it.
Old Mar 10, 2007 | 07:07 PM
Elvota's Avatar
So... will a narrower rim have better bead retention on a 12.5" tire or worse?
Would the 10" rim with a 12.5" wide tire have a bigger footprint at lower PSI than a 8" rim with 12.5" tire?
Old Mar 12, 2007 | 07:38 AM
Yota Tony's Avatar
narrow rim will give better bead retention.
8" rim will cause the tire to ballon/buldge more then a 10" rim.
Old Mar 12, 2007 | 07:42 AM
mastacox's Avatar
I run 33x12.50's on an 8" rim, they worked perfectly. I actually prefer the look of a 12.50 on an 8" wide rim rather than a 10" wide rim, which seems a little too close to the width of the tire.
Old Mar 12, 2007 | 03:12 PM
westy44runner's Avatar
It will have better bead retention with the 8" wheel. I ran my old 35s on 15x8's at 5psi constantly...it worked great.
Mark is running those 36x13.5 Iroks on 15x8's...no issues at all.
Which Toyota alloys are you looking at? The ones that came on the 90-95 4runners/pickups with SR5 package? If so, I think those are 15x7 wheels. I would be cautious of the backspacing too.
Old Mar 12, 2007 | 03:14 PM
Elvota's Avatar
Yeah Westy.... I was looking at some off a Tacoma, but the backspacing was wrong.
Don't really have issues with the way mine are working now, just looking at options.
glowz825
Jan 25, 2022 09:28 AM
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
