TRD Boost Gauge range
Old Jan 25, 2007 | 07:27 PM
heyben's Avatar
For those of you who use the TRD boost gauge with your supercharger:
What is the range your needle generally moves between the In.HG. side and the PSI side during normal driving conditions?
I just reinstalled my SC after a rebuild, and it appears to be dropping deeper into the IN.HG side (near 20) than I remember during its prior installation. This occurs when I let it idle or let off the gas while driving. I seem to remember it hovering around the 0 mark between In.HG and PSI at the top of the gauge. The gauge still registers 6 psi when I pin it, so that side of it appears to be normal.
Do you guys usually see this much fluctuation, or have I screwed up somewhere in the reinstall?
While we're on the topic, what the heck does In.HG. stand for anyway? I googled it and found out that it is a measure of atmosphere, but have no idea how that relates to the function of the SC...
Thanks for your help
Old Jan 25, 2007 | 07:33 PM
Greg_Canada's Avatar
Hg is a measure of vaccum.
Hg is mercury
Old Jan 26, 2007 | 12:02 PM
heyben's Avatar
Anyone know the standard range the gauge should fluctuate in a 2000 Runner?
Old Jan 26, 2007 | 12:08 PM
Angus1's Avatar
the more vac the better. mine is pined on the vac side at idle and makes about 6 or 7 pounds of boost 04 tacoma 3.4 stick
Old Jan 26, 2007 | 12:09 PM
04 Rocko Taco's Avatar
In.HG is the abbreviation for inches of mercury. It is a calculation to figre vacuum, something about how many inches of mercury it can pull at that -PSI, or vaccuum.
Old Jan 26, 2007 | 12:12 PM
JHRRLD's Avatar
My 2000 SC'd 4runner pulls ~20HG when at idle and up to 7.5 to 8psi in boost. And it is normal for a SC to pull vacuum when at idle.
Old Jan 26, 2007 | 12:33 PM
heyben's Avatar
Thanks for the responese! Seems like my supercharger is even more "Super" since the rebuild...
Old Jan 26, 2007 | 01:30 PM
midiwall's Avatar
Double ditto.
Old Feb 1, 2007 | 01:09 PM
mrmojorisinphan's Avatar
Originally Posted by midiwall
Double ditto.
Tripple dipple ditto
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
suppra87
Jul 15, 2021 05:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
sonorn67
Sep 19, 2015 05:39 PM
jacked_72
Sep 14, 2015 03:31 PM
