Timing Chain
Old Jun 4, 2010 | 08:36 AM
Airo Spade's Avatar
Timing Chain
Wondering what else i should change on my first timing chain swap second engine, no clue actual mileage
Old Jun 4, 2010 | 09:11 AM
jammer1313's Avatar
What ever looks like it needs to be replaced while your under the hood, I guess, that's what I would do...
Old Jun 4, 2010 | 10:13 AM
Airo Spade's Avatar
but thats everything
Old Jun 4, 2010 | 10:25 AM
DeathCougar's Avatar
talk to Ted at Engnbldr
For sure replace:
Chain
Guides
Tensioner
Gaskets
Main seal
Old Jun 4, 2010 | 10:32 AM
Airo Spade's Avatar
main seal?
Old Jun 4, 2010 | 10:41 AM
aka Front Crank seal, aka Harmonic Balancer Seal, aka Timing cover front seal
Old Jun 9, 2010 | 09:13 AM
Airo Spade's Avatar
another question do i have to remove the head when I do this the book and all data says should but. Is it necessary
Old Jun 9, 2010 | 09:51 AM
4Crawler's Avatar
Head removal not necessary:
- http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Old Jun 9, 2010 | 10:06 AM
Head removal is not technically necessary, but I always do and replace the head gasket at the same time.
22RE motors are resiliant, but Toyotas specs call to replace the timing setup and head gasket at a regular interval. Those are the two weak points on a 22R/E motor, so if you replace them at the same time, the motor will last for a very long time.
Old Jun 9, 2010 | 10:58 AM
Airo Spade's Avatar
how long does it take without taking off the head something i can do after work or a weekend project. I work at a shop and its estimated time is 7.5 hours with head removal
Old Jun 29, 2010 | 04:46 PM
Airo Spade's Avatar
So Im doing the timing chain as we speak and Im trying to figure out how to get the back alternator bracket bolt off. Its being blocked by the power stearing. Do i have to remove this?
Old Jun 29, 2010 | 04:51 PM
Airo Spade's Avatar
Nm im a dumb ass
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
