Simple oil change questions
Old Feb 4, 2006 | 09:53 AM
L33T35T 4Runner's Avatar
I was at the dealership yesterday getting some oil filters for 4 different cars
85 4runner 22re
90 4runner 22re
95 4runner 3vze
00 sienna V6
they ended up all being the same filter. can anybody confirm this? i know both v6 have the same filter, but i thought the 22res and the v6's had a different filter
TIA
Jason
Old Feb 4, 2006 | 10:06 AM
Paul H.'s Avatar
according to this site, they are the same.http://replacement.autopartswarehous...Filter&dp=true
Old Feb 4, 2006 | 10:07 AM
NicksBlue934runner's Avatar
Oil Filters
try autozone.com or a carparts store website they let you pick your year make and model and then they have all of the information they have at the store
Old Feb 4, 2006 | 10:18 AM
spindleshanks's Avatar
According to WIX filtration, they're all the same except for the '85 22RE. Often times when different oil filters are similar in size and filtering capabilities, the manufacturer will consolidate them into one part number. It's cheaper for them because they can manufacture less part numbers. This practice is most common with value oriented filter companies such as Allied Signal (Fram) and Champ.
My catalog shows the applications as WIX part number 51348, except the 85, which is WIX part number 51068.
Old Feb 4, 2006 | 11:04 AM
kyle_22r's Avatar
don't know about the 51068, i know the 51348 is the specified filter for the 22R-E. on my 20R and 22R engines, i've always liked to use a 51515 filter, which has about twice the capacity of the smaller one(it's a small block ford app, as well as toyota diesel). i used one on my 22R-E, but it's a bit of a tight fit in there.
Yoda's Avatar
the 1068 is a larger filter than the 1348 (NAPA #'s, made by Wix) I prefer to use the larger filters. Same with the V8 in my cruiser. I use the larger filter with the antidrain valve (wasn't standard on my 69 engine block, but is a direct replacement)
Old Feb 4, 2006 | 02:51 PM
The 51515 and 51068 are interchangable? That's cool. More oil is always better. Here are specs for all the following filters. Sure enough, the essential specs are the same for all of them: the micron rating, the flow rating, the filter media. They all have the same threads, they all have anti-drainback valves (silicone) and the 068 and 515 have the same gasket dimensions. Neat.
Part Number: 85348
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Part Number: 85068
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Gasket Diameters
Attached 2.834 2.462 0.200
Part Number: 85515
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=19/41
Burst Pressure-PSI: 270
Gasket Diameters
Old Feb 4, 2006 | 02:59 PM
[QUOTE=kyle_22r]don't know about the 51068, i know the 51348 is the specified filter for the 22R-E.QUOTE]
I double checked the latest cataloging and the 068 is, in fact, the correct filter for the 85 model according to WIX.
Old Feb 4, 2006 | 03:13 PM
Tacoma Dude's Avatar
The box the filter comes in should tell you what engines they're applicable to. I was surprised to see that my 5vzfe V6 and the 22RE 4cyl took the same filter too.
Old Feb 4, 2006 | 03:36 PM
I don't know of any filter brand that prints the application on the box. The only sure way to know is to consult an up-to-date catalog. Check out www.wixconnect.com. You can register there (it's free) and use their cataloging, interchange, and spec data.
Old Feb 4, 2006 | 06:27 PM
thanks everybody
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
