Old Mar 23, 2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Exterior Guides
Print Wikipost
Show us your best cheap mods!
Old Apr 11, 2011 | 09:56 AM
  #541
andrewflores17's Avatar
yeah just some dinky little AAA battery's so i left it on the bright setting all night just to test it out looked at it this morning and still nice bright
bet if someone was creative enough though they could wire it up to the truck battery
Old Apr 11, 2011 | 10:02 AM
  #542
irab88's Avatar
easy enough to do. how many batteries per light? 3?
Old Apr 11, 2011 | 10:22 AM
  #543
thiers 4 lights each light contains 3 leds and thier 6 AAAs 3 to the left side and 3 to the right
Old Apr 11, 2011 | 10:57 AM
  #544
Junkers88's Avatar
Originally Posted by irab88
nice... you wouldn't happen to have any pics of inside the cowel area, would you?
Originally Posted by JBurt
With your new intake route did you do anything to divert the water that gets into your cowl (i.e. when it rains, or at the carwash) from going into your intake pipe? Just curious.
No pictures of the cowl area guys, sorry I was in a hurry to get the fender back on. The ducting is angled upwards at the bottom and is mounted a couple inches up off the bottom of the cowl interior so water can't get in there. This is just the first attempt. I'll be redoing it later on with some tubing and making a penetration through the cowl to mount a snorkel head, at least that is the plan.
Old Apr 11, 2011 | 11:22 AM
  #545
BigBluePile's Avatar
There's a build thread on here soooooooooooooooooomewhere where a guy made a snorkel that went thru the cowl. Custom airbox, supra AFM. It was pretty trick...
Old Apr 11, 2011 | 11:27 AM
  #546
Junkers88's Avatar
Old Apr 11, 2011 | 11:38 AM
  #547
irab88's Avatar
6 aaa's per light unit, or 6 for the whole fixture?
Old Apr 11, 2011 | 01:18 PM
  #548
http://www.harborfreight.com/four-he...ght-96794.html
6 AAA overall
Old Apr 11, 2011 | 01:50 PM
  #549
old fart's Avatar
Here's one, hood latch easier access mod
Old Apr 11, 2011 | 01:56 PM
  #550
old fart's Avatar
Or this, cruise control and aftermarket A/C (both never used)
Old Apr 11, 2011 | 01:58 PM
  #551
old fart's Avatar
This looks like a mod but i have no idea what the purpose is, any clues?
Old Apr 11, 2011 | 02:26 PM
  #552
im steeling that hood latch trick thats so simple gona save me alota headaches
Old Apr 11, 2011 | 02:56 PM
  #553
Outsane's Avatar
looks like pulling some slack out of the cruise control cable
Old Apr 11, 2011 | 03:06 PM
  #554
irab88's Avatar
then you need a circuit like this:
it uses a piece of equipment known as a voltage regulator, which keeps the output voltage at a constant 9v, with a varying input (anywhere from ~10 to 24). the part number is 7809, and i can get a better diagram tomorrow (that one is just a stock photo). pretty easy to wire up and hide in where the batteries used to be
Old Apr 11, 2011 | 03:08 PM
  #555
irab88's Avatar
if the dashpot is clogged, and/or the return spring is weak, that will act as the return spring. an easy $1 fix (no, it's not mine, but it's my best guess)
Old Apr 11, 2011 | 03:31 PM
  #556
Swimmerboy2112's Avatar
Haha i hate you Ian! hahaha
Old Apr 12, 2011 | 05:14 AM
  #557
old fart's Avatar
ok ty for the chain link clues i'll have to check into those suggestions, i bought the truck 2 yrs ago, and didn't really notice it till this yr, lol.
Old Apr 12, 2011 | 05:20 AM
  #558
irab88's Avatar
oh, the chain link? whoops. i have no idea what it's for. i was talking about the spring
Old Apr 12, 2011 | 09:04 AM
  #559
irab88's Avatar
here's a better diagram of how to connect the parts
you'll use the 7809 part
Old Apr 12, 2011 | 11:17 AM
  #560
MudHippy's Avatar
As was suggested, I'll throw this in here too.
IFS Passenger-Side Axle Stub Shaft Mod.
Originally Posted by MudHippy
I just finished up one of the three I've got. I used a 3/16" drill bit and a 1/4" 20 NC tap. I made the hole ~7/16" deep.
Looks like this when done correctly.
I'll probably use a shorter bolt 1/4" grade 8 bolt for pulling it. This one is for demonstration purposes.
Why do that you say?
Because this happens.
The bolt gives you a pulling/prying point on the piece still stuck in the diff, making it possible to remove. It's held in by a flexible c-clip on the end that requires quite a bit of force to pull past the side-gear before it will slide out. Otherwise you'll have to remove the diff cover and force it out from the inside. This mod will turn a job that would normally take about an hour start to finish, into a 5 minute snap-of-a-finger-quick-bang-done-forget-it deal.
