Seafoam Injector / Intake Cleaner = GOOD STUFF
Old Nov 24, 2004 | 09:34 PM
  #341
keisur's Avatar
10 seconds? that doesn't sound right.
Old Nov 25, 2004 | 04:47 AM
  #342
callmej75's Avatar
thata what i thought. gonna try it again today and see what happens.
Old Nov 25, 2004 | 06:03 AM
  #343
callmej75's Avatar
ok now i got smoke! its still smoking as we speak...and yeh it does idle a little smoother now. i think i didn't ass enough last night and im on my second time around and added about 1 whole can to 1/2 tank before i go down to fill up. let it clean the jectors' out a little. hope you guys have a great thanksgiving and this is a more informative sight rather than some jackasses at a dealership!
Old Dec 4, 2004 | 11:37 AM
  #344
88toyotacorollafx's Avatar
hey everyone, this is for the ppl interested in the sea foam for automatic transmissions...called sea foan Trans Tune. I guess i was the only one in this forum to have the guts to try this stuff on a high milage trans....well i did. My car has 140,000 miles on it and has been neglected and serviced like ˟˟˟˟ in the past. This was one reason i didnt wanna use this stuff at firstcause i didnt wanna free up too much harmful sludge, varnish, and gum. Anyways i used it, the bottle says drive at least 5 miles with it in ur trans...i drove about 75 miles with it in my trans. It also says change the fluid and filter after. I just took off the pan, change the fluid and cleaned the pan and magnet. Left the filter where it was without changing it cause it only had 9 thousand miles on it. ANyways...the result was, i notice much better and smoother shifting...MUCH BETTER
i guess it was pretty noticable for me cause my trans was getting all dirty and worn out..so this stuff did alot of good.
Dont be scared to try this stuff out ppl
its worth $4.99 instead of waiting till ur trans goes out or gets super bad
Old Dec 4, 2004 | 07:10 PM
  #345
yotaluver's Avatar
wish i could do this but the dude that had my truck befor me cross-threaded the spark plugs so i had to lock-tight them to make them seal. so now i don't reall want to pull them out and put new ones in cuz i just don't want to mess with the plugs.
Old Dec 5, 2004 | 07:18 AM
  #346
Amir904's Avatar
i got a check engine light, is it related to the seafoaming? i seafoamed 1000 miles ago. checked it out at autozone, error code, P0133, which is the O2 sensor... anyone else have this problem?
Old Dec 8, 2004 | 10:08 AM
  #347
theryanator's Avatar
Ok so it has taken me two days to read through this very informative post.
I have terrible luck when it comes to cars so I am hesitant, but willing and looking forward to giving the SeaFoam a try. I just want to make sure I do everything right AFTER I use it.
Questions:
The likely complications that could occur are 02 sensors getting clogged, what about the Catconverter?
The Spark Plugs will get gunked up. What is the longest they can go like that without replacing them? I will be doing a tune-up in January when at my in laws...he is a mechanic. I just wanted to know If I could do the seafoam now and drive it for a month or so like that.
You should change your oil within a couple days of the treatment correct?
Is putting through the pcv valve more effective than the brake booster line?
Should you put it through both to target both sides of the engine case?
What is the best way to clean the MAF and also the 02 sensors if they get plugged up. Are 02 sensors easy to access and remove to clean once you are under the car?
Thanks for the input for whomever decides to tackle this post...I am learning a lot!
Old Dec 8, 2004 | 10:15 AM
  #348
bamachem's Avatar
I never got a CEL, but after the first treatment, my gas mileage dropped. I pulled both O2 sensors and cleaned them and it went back to normal. I did antoher intake treatment a few weeks ago, and about 5 or 6 days after I did, my MPGs went down again. I cleaned the O2 again and it didn't change anything this time. Last week I ordered a new front O2 from URD to see if it may indeed be the culprit. I have 117k on this set, so it's about time to change them anyway and I don't know if Seafoam may or may not have contributed it's failure.
Old Dec 8, 2004 | 10:17 AM
  #349
By the way I have a 99 4 runner SR5 with 134 K on it.
What is a decent brand of plugs and wires to get for this truck?
And can anyone identify the BRAKE BOOSTER and PCV valve for me on the 3.4 engine that is in the 99 Sr5s. I just want to be certain that I am putting it in the right place.
thanks.
Old Dec 8, 2004 | 10:30 AM
  #350
bamachem's Avatar
PLUGS: Denso or NGK (best are the denso plugs from your dealer)
WIRES: OEM from your dealer, but they should be fine.
Old Dec 8, 2004 | 10:46 AM
  #351
You mentioned "from your dealer" is it not advantageous to get them from a Napa store? What do the Denso or NGKs run price wise and are they fairly easy to gap? I have never done my own plugs before, but I have watched it be done and it seems simple enough.
Old Dec 8, 2004 | 10:49 AM
  #352
You mentioned "from your dealer" is it not advantageous to get the parts from a napa store?
Also what do the NGK or Denkos run cost wise? Are they fairly easy to gap properly? I have never done plugs myself before, but it looks simple enough.
thanks.
edit: sorry about the double post...for some reason I thought the first one did not go through.
Old Dec 8, 2004 | 10:52 AM
  #353
colsoncj's Avatar
I run NGK's on mine and haven't had a problem with them. cost is about 1.30 a piece (give or take some depending on what kind of plug you get.) Gapping is easy, just buy a spark plug gapper or a set of feeler gauges, and check your truck for the proper gap (if I remember correctly it says what the gap is on the sticker under the hood), then set the plugs to the spec.
Old Dec 8, 2004 | 10:59 AM
  #354
keisur's Avatar
they are about 50 bucks from the dealer for the 3.4 liter wires.
plugs are pregapped from dealer.
Old Dec 8, 2004 | 12:25 PM
  #355
TacomaTRD's Avatar
Take it to a shop and have them heli-coil the threads...
Old Dec 15, 2004 | 05:27 AM
  #356
Amir904's Avatar
does anyone else have diminishing gas mileage after seafoaming?
Old Dec 15, 2004 | 05:35 AM
  #357
callmej75's Avatar
My gas mileage went up a little...maybe 10 miles to the tank
Old Dec 15, 2004 | 05:43 AM
  #358
bamachem's Avatar
mine went up and stayed up for a while, then with over 115k, my front O2 started crapping out. i just replaced it, and my mileage appears to be back up.
clean your MAF and your front O2 sensor.
Old Dec 15, 2004 | 06:09 AM
  #359
ravencr's Avatar
Mine has dropped tremendously.
Chris
Old Dec 15, 2004 | 08:45 AM
  #360
Amir904's Avatar
how many cans of seafoam should i use before i start gaining mpg?
