Seafoam Injector / Intake Cleaner = GOOD STUFF
Old Aug 21, 2004 | 08:21 AM
  #281
10cents's Avatar
Hey guys, im new here and this is my first post. I bought a can of this stuff the other day and was reading this thread to find out how to use it. I have a 1990 pickup with a 22re. I know to disconnect the PCV hose and pour in there but can I also spray into the intake? Would that help? I also bought some TB cleaner, is that going to be useless to me now?
Old Aug 21, 2004 | 07:44 PM
  #282
Tacoma Dude's Avatar
I got one more question for you guys - with or against the flow of the vaccuum.
Just want to make sure
Old Aug 21, 2004 | 08:48 PM
  #283
midiwall's Avatar
"With or against"? You want to pour it into the hose that's sucking. The suction is coming from the manifold vacuum, and you want the Seafoam to end up in the manifold.
Old Aug 21, 2004 | 08:49 PM
  #284
Okay, just checking
  #285
midiwall's Avatar
Okay, just checking
GO FER IT DOOD!
Old Aug 21, 2004 | 08:52 PM
  #286
Still trying to figure out how I'm going to get it down the pipe while holding the throttle so the engine doesn't stall...
Old Aug 21, 2004 | 08:57 PM
  #287
midiwall's Avatar
Hmmm... it shouldn't be an issue Peter. If you pour it slowly enough then it won't stall. I've done it three times now through the PCV tube and haven't stalled it yet. I think the talk about stalling and getting a buddy to rev the engine is mostly about "once you start pouring, you'll get a better understanding of what's happening".
Also.. wait a LOT longer than the "15 minutes" on the can. I've had great results from 2 hours or more. In fact, I did it again today, let it sit for about 4 hours and when it started a bunch of watery sludge came shooting out the pipe (along with Le Smoke Cloud ). That was "k3wl".
Old Aug 22, 2004 | 12:09 AM
  #288
I'm having trouble with keeping the engine going once I remove the PCV valve.
Thanks for the tip on letting the stuff sit though. That's good to know
Old Aug 22, 2004 | 12:18 AM
  #289
Mossback74's Avatar
You gotta put your thumb over the hose right away, otherwise it'll lean out
Old Aug 22, 2004 | 06:37 AM
  #290
bamachem's Avatar
Originally Posted by midiwall
I haven't, but given what other folks have said, it could be a result of the junk that Seafoam loosened up.
I'd pull the O2 sensor, hit it with intake cleaner, let it dry, and put it back in. I think you'll be okay.
I did the same thing along w/ the spark plugs. Took about 30 min total for all of them.
Old Aug 22, 2004 | 10:07 AM
  #291
keisur's Avatar
Originally Posted by DrummerDaveB
Hydrolocking is very very bad. If you stick the hose in the can, there's a good chance you'll do it. So dont.
That's why I poured mine out of the can and into a glass jar so I could hover the hose inlet just above the meniscus and slowly slurp it up with alot more air than Seafoam. Takes some time but you won't hydrolock it that way.
Old Aug 22, 2004 | 10:10 AM
  #292
keisur's Avatar
Pour it into a jar, Mark it off into 1/3's, extend the hose from the PCV valve to the manifold, set the jar on the bumper or airbox or something, put a thumb on the throttle at the throttle body, slowly begin sucking it in like I state above, and if it starts to stall push the throttle with you thumb a little.
Old Aug 23, 2004 | 07:33 AM
  #293
Scarface's Avatar
Just did it on my 90 3.0, put 1/3 in intake, full can in gas tank, smoked a little nothing major, drove down the street and back and it seems like it helped a little, maybe once the can in the gas starts working I will notice alot more, now my BMW on the other hand, WOW, it helped out a pretty good bit!
Old Aug 23, 2004 | 09:57 PM
  #294
funkblaster's Avatar
Yeah i used and had dark smoke coming out for 10 min. I can definitly tell a difference. It purrs.
Old Aug 23, 2004 | 09:59 PM
  #295
Funny - I did mine today and barely noticed any smoke. It was white too... maybe my cat is clogged?
Old Aug 24, 2004 | 03:47 AM
  #296
bamachem's Avatar
Maybe you didn't get enough in there. Try a couple of intake treatments and you'll get the blue/white smoke...
Old Aug 24, 2004 | 01:31 PM
  #297
I'm thinking maybe I didn't wait long enough. I waited an hour but I was thinking about it and when I attempted to clean my TB last Saturday the stuff in there was like black pancake syrup... I probably should have waited longer.
Man, it really does hurt to have to pinch that line for so long!
Old Aug 27, 2004 | 10:37 AM
  #298
DrummerDaveB's Avatar
Thats why you use pliars.
Old Aug 27, 2004 | 10:46 AM
  #299
Yeah, I was thinking about that for the next time I run the stuff through
Old Aug 27, 2004 | 11:50 AM
  #300
slow_xc_star's Avatar
So can i pour this stuff right through the intake??? Will my engine do the same thing(start to stall) if i can put it through the intake??
Thanks!
