Seafoam Injector / Intake Cleaner = GOOD STUFF
Old Nov 13, 2006 | 02:21 PM
  #481
mburnickas's Avatar
I agree seafoam for the price is a darn good deal. I also tried their Deep Creep. Works better for hard-to0reach areas.
You can also use FP60 and it does a little better. It does a little better since it does not evaporate as fast.
Old Nov 13, 2006 | 03:19 PM
  #482
RunnerUp's Avatar
well about 10 minutes after i poured the second can into my crank case and my gas tank i threw a CEL with the P0171 code so im about to go out and clean my MAF and reset my ECU while also throwing another batch of seafoam in to let sit overnight... will let you guys know how everything turned out in the morning
Old Nov 13, 2006 | 03:34 PM
  #483
midiwall's Avatar
Originally Posted by RunnerUp
...thanks for the help midiwall!
aye dude. This thread's pretty long, and I think there are two others so it's hard to clog through it all.
"One Of These Days" there will be a FAQ where we can point people and not have to re-re-re-repeat the info.
Glad to hear you made it through the first time! There are a couple of folks around that have people saying they've really PO'd the neighor...HOOD (as in a LOT of people) with doing this.
"oops".
Old Nov 13, 2006 | 03:53 PM
  #484
RunnerUp's Avatar
yeah... when i pulled my MAF there was smoke coming out of the hole it plugs into so.... whatever that means
good for me i live in a college town and so no one seems to think anything of a truck spewing thick smoke for 10 minutes, or atleast they dont say anything, just cleaned the MAF and am gonna reinstall it in the morning before i gotta go to class so... hopefully that will be the end of my seafoam trial, if my CEL goes out then i will be happy with the procedure
Old Nov 13, 2006 | 08:14 PM
  #485
kevinfromseattle's Avatar
i have a 99 lx470, its pretty sweet but has a load of miles from my parents. I want to use the seafoam, but have no idea what tube is the pcv tube. how do i find that?
Old Nov 13, 2006 | 09:58 PM
  #486
RunnerUp's Avatar
im not sure on that motor, easiest way would be to go to toyota and ask to buy the PVC hose, and look at the little diagram of parts they have, it should be a little rubber hose attached right after your throttle body that connects to your block via a 90* white plug. just be sure your putting it in the right whole, lots of stuff can go wrong when you do something like this if you arent sure where or what you are doing
Old Nov 13, 2006 | 10:49 PM
  #487
bob200587's Avatar
"oops".
I'm gonna try to do a photo write up on the seafoam treatment if I ever get around to it. If I do I'll be sure to get it posted.
Old Dec 14, 2006 | 09:46 PM
  #488
LS1Steve's Avatar
i'm not saying seafoam is a bad thing, but its just a normal injector cleaner people. everyone gets all excited watching the smoke thinking the magical fluid is removing all that gunk in the engine.....there are a million things you can pour into the engine and make it smoke. drop some diesel fuel in there and watch it smoke....doesn't mean its doing a damn bit of good! I prefer an O2 sensor safe spray cleaner into the TB, it won't foul plugs. The diluted seafoam into the gas tank is the only way i'd use it for the injectors.
Old Dec 30, 2006 | 04:24 PM
  #489
Th3duke's Avatar
This stuff really worked
1990 4x4 Pickup, 3.0
I live in Canada, Quebec, and couldn't find this stuff anywhere, but found it on e-bay (3 bottles). Anyway, I've had a hesitation and stumbling problem for a long time, did the regular tune up stuff: Plugs, wires, rotor, dist cap, air filter... Cleaned the TB, and IAC, and finally changed the oxygen sensor. Although there was some improvement it still ran a little sluggish. I also added lucas fuel conditioner for about 10 fill-ups and it still was sluggish. Anyway, after reading this thread, I decided I would try the sea foam... picked up 3 bottles for 25.00 USD and plus 10.00 US for shipping (yeah, I know it's kind of pricey). Regardless it WAS WORTH IT!
I used the brake booster hose and slowly put in half a pint, let it sit for 15 minutes started it up, and it smoked for about 5 minutes (whitish/grey smoke) -- took it out for a drive and it seemed to be running better. I then put the other half of the pint through the booster and let it sit again for 15 minutes, took it for a drive, and it started getting even better. SO I then decided to take another pint and put the whole pint in on a half tank of gas. I've been driving it for about 60 KM and the truck has never run so good.
All this to say, this stuff works! THANK YOU to everyone on this board for letting me in on this stuff -- you guys truly rock!
Old Jan 10, 2007 | 01:36 PM
  #490
GodwinAustin's Avatar
is it a good idea to rev the engine after restarting the engine after adding seafoam through the PCV vaccum hose? I figure that would do a better job clearing the carbon and gunk out. Just added almost a full can today. first time just let it idle after restart. The second time I revved it a bit. What do you guys think?
Old Jan 10, 2007 | 01:44 PM
  #491
Also, does it help to drive the truck, putting the engine under load, after adding the seafoam throught the vaccum hose,or is it just as effective to let it sit and rev a bit in neutral?
Old Jan 10, 2007 | 01:53 PM
  #492
midiwall's Avatar
I dunno that I'd go do a drag race, but I tend to start the engine, let it warm a bit (2-3 minutes) then go for a drive. My immediate neighbors tend to appreciate me doing that since it minimizes the amount of smoke they have to ingest. Of course, the rest of the 'hood isn't too happy...
Old Jan 10, 2007 | 02:25 PM
  #493
OSU4Runner's Avatar
Hey guys, I'm thinking about doing this treatment, kinda scared, but it sounds like it works good. If I pour it into the crankcase, do I need to change my oil after using it or is it ok to drive with? Do you guys use it right before you're do for an oil change?
Matt
Old Jan 10, 2007 | 02:36 PM
  #494
91TPU's Avatar
i would do it a day or two before you do the oil change, and i wouldnt put any more then like 50 or 60 miles on the truck during that time. so yea i would change the oil after you put the seafoam in, just not like 2 seconds after
Matt
Old Jan 11, 2007 | 05:37 AM
  #495
no need to change the oil if only fed throught the pcv/vaccum, right?
Old Jan 11, 2007 | 05:52 AM
  #496
91TPU's Avatar
no but when i did it i fed it thru the brake booster and into the gas tank...then the week after i changed the oil...for me it was totally coincidental, oil didnt look any different, just as it shouldnt.
Old Jan 11, 2007 | 09:28 AM
  #497
Th3duke's Avatar
I just put some in my crank case yesterday, and drove the truck for about 50 KM. I then did an oil change and watched the black goo come out. This stuff really works. Engine seems quieter -- BTW: I e-mailed sea foam and they told me where I could find it in Ottawa, Ontario -- so no more pricey e-bay shopping for the stuff. I picked it up for 8.99 CDN.
Old Feb 20, 2007 | 10:28 AM
  #498
Fergie's Avatar
Okay, I've started the Seafoam treatment, gas tank only so far, and have looked at all the pictures, but am still curious about one thing, and jsut need some kind of confirmation.
Mine is an '86 Turbo, the fact that it is a Turbo shouldnt affect what hose I use or anything like that, correct?
Thanks
Fergie
Old Feb 20, 2007 | 12:49 PM
  #499
blinkybill04's Avatar
great stuff! used it on my civic with great results, smoothed idle, better mileage, whole 9 yds.... havent read the entire 20+ pages, but thought it would be an important note to say using seafoam on cars w/ 150k+ is a bit of a gamble. i know people on the honda boards said higher mileage vehicles may leak and what-not. i JUST bought a taco w/170k and kinda debating using it... great stuff though!
Old Feb 20, 2007 | 02:12 PM
  #500
964runnerKY's Avatar
seafoam does good sometimes.
