Seafoam: Before & After Pictures!!!
Old Dec 20, 2011 | 07:31 PM
RamRod82's Avatar
So I was cleaning my throttle body yesterday & when I looked into the plenum I was blown away at how much sh** was stuck on the walls. So I thought this would be an awesome opportunity to see if Seafoam is for real or just another scam. These are pics of the inside of the plenum from where the throttle body sits (duh). I poured 1/3 pint (1/3 of the can) through the PCV vacuum line for more even distribution with engine running, killed engine & let sit for 5 minutes then ran at about 2,000 RPM till the white smoke stopped spewing out. This is a 1999 Limited 4Runner with the 3.4L V6. Judge for yourself if it's worth $10.
BEFORE
Seafoam: Before & After Pictures!!!-12-19-3-x.jpg
AFTER
Seafoam: Before & After Pictures!!!-12-20-2-x.jpg
Better throttle response, seems to idle a little smoother and now I have photographic evidence that it does clean most, not all, of the gunk. Hopefully i'll get a little better gas milage too. I'd say it's worth $10 every oil change. I did notice though that the Seafoam didn't distribute as evenly as I thought it would. The forward most and aft "channels" in the plenum didn't get as clean as the middle "channels" did.
And if anyone from Seafoam wants to send me anonymous checks for large sums of money I will happily accept
Last edited by RamRod82; Dec 20, 2011 at 07:33 PM. Reason: Sorry the pics are so small, couldn't figure out how to make them bigger so you could see better detail
Old Dec 21, 2011 | 05:58 PM
aviator's Avatar
good pics ramrod... nice to se that stuff actually works... kinda sorta...
Makes you think if they had it in a spray bottle with a long wand you could get better control of where it goes...
Old Dec 22, 2011 | 06:13 AM
snobdds's Avatar
I have heard that running the stuff through the PVC is better than the brake booster, well now here is the proof.
Old Dec 22, 2011 | 06:52 AM
93toyrunner2's Avatar
They do have SeaFoam in an Aerosol can, with a long rubber U jointed plastic hose to allow you to get it into your throttle body while spraying from outside. I tried it and was not impressed. Went back to the liquid in the PCV hose.
Old Jan 25, 2012 | 05:36 AM
sided00r's Avatar
I just read about two people's head gaskets blowing after a seafoam treatment - what are the risks involved with the stuff??
Old Jan 25, 2012 | 05:50 AM
MudHippy's Avatar
None, nada, zero, zip, zilch...
What you heard was paranoid tweaker talk. There's no way in hell it's going to cause a blown head gasket or any other engine malfunctions. So when you hear the rumor that you can hydrolock your engine with it, you can toss that garbage out too.
GOOD STUFF, USE IT!!! DON'T BE A DRAMA LLAMA!!!
Old Jan 25, 2012 | 06:41 AM
Red3.slow's Avatar
Great pictures! Seafoam is some good stuff!
Old Jan 25, 2012 | 08:14 AM
I have used SeaFoam for years in multiple 4 & 6 cylinder engines, and nothing but total positive results from it! I have never heard anyone that uses it say anything about blowing up head gaskets. Now if you suspect your head gasket is about to go, then I would suggest a compression test first, obviously.
Old Jan 25, 2012 | 08:42 AM
cman1's Avatar
its a great way to find all your exaust leaks too!!!!
Old Jan 25, 2012 | 08:52 AM
woodyth's Avatar
Dad always told me to put it in the gas about every 6 months, which I do to all my vehicles. Never thought to pour it in the pcv, now I have a weber installed, I want to pour it in the vacuum line that comes off the back of the valve cover right? . its a 87 22r
Thanks
Woody
Obmi
Nov 24, 2015 11:37 AM
jaretstuff
Oct 22, 2015 05:25 PM
user 82300
Sep 15, 2015 05:49 AM
