Is this rod knock?
Old Sep 14, 2007 | 07:00 PM
4RocRunner92's Avatar
Is this rod knock?
If it is, I'm glad I kept the 4runner.
http://www.youtube.com/watch?v=rmFFAcTTJZY
the vibration during 29 seconds to 33 seconds is just the console. so exclude that please.
thanks
Old Sep 14, 2007 | 07:04 PM
stormin94's Avatar
You'll know if it's a rod knock
Old Sep 14, 2007 | 07:06 PM
stormin94's Avatar
That sounds like a valve to me. Does it make the car move, or vibrate pretty bad?
Old Sep 14, 2007 | 07:24 PM
callmej75's Avatar
Sounds like it to me..try some really heavy weight oil in it like 50w and see if it is noticeably more quiet. If so...you have pretty much found your culprit. If the sound stays the same for quite a while...like weeks later, then it could be a wrist pin going bad. They can last from 1 day to 12 months later. Its a crapshoot with a wrist pin.
Old Sep 14, 2007 | 08:57 PM
SolidDigital's Avatar
My truck sounds almost just like that once it's warmed up but not quite as noticeable with the hood closed. I thought it sounded like it was coming from the fan though..
Old Sep 15, 2007 | 11:46 AM
I should park it right?
Old Sep 16, 2007 | 03:18 PM
Adam F's Avatar
Almost sounds like a stretched timing belt slapping the cover. Get a long screwdriver and put your ear on it and put it on the timing belt cover(s) and listen. This is the same noise my 96 Rav-4 made when the timing belt was worn out.
Old Sep 16, 2007 | 03:58 PM
DeathCougar's Avatar
Sounds like timing belt to me as well.
Old Nov 22, 2007 | 04:18 AM
Blitzkrieg's Avatar
Well, what was the noise? Mine sounds similar but has for about 80 thousand miles. I think it's getting louder and needs to be fixed. Any easy ways to determine what it is? Thanks
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
moparbay
Oct 6, 2015 09:24 AM
