parabolic leaf springs
Old Jan 5, 2009 | 10:53 AM
Swansen's Avatar
I didn't know they existed, but they are the sweetness.
http://www.parabolicsuspension.com/general.htm
Old Jan 5, 2009 | 10:56 AM
Ed H.'s Avatar
interesting i have never seen anything like that before
Old Jan 5, 2009 | 11:05 AM
drew303's Avatar
never heard of but they seem to be more of a stock upgrade to provide a better ride and bit more flex.
All their springs are relatively flat (not much arch)
Old Jan 5, 2009 | 11:12 AM
Swansen's Avatar
i stumbled upon these link earlier, but lost them at the time of posting, anyways, got them again.
http://www.man-a-fre.com/pa/hstparabolicleafsprings.htm
http://www.eastcoastrover.com/Parabolics.html
Old Jan 5, 2009 | 11:31 AM
Swansen's Avatar
They can be made to any specification, and i'm sure they could make them as lift springs also. They are better than conventional leaf springs in every way. On leaf spring arch, i was under the impression that less is better, while not being flat, you get to much arch and you loose flexibility.
Old Jan 5, 2009 | 12:01 PM
dropzone's Avatar
Fossilized
Those parabollic springs sound good but I guess they do not perform as well as
predicted. They are said to perform well when installed with an axle mounted over the spring. It turns out they did not live up to expectations when mounted in a SPring over axle situation (like most toyota 4wd axles)
4WD Toyota OwnerMagazine did an install on an FJ40 in the May/June '07 issue
pages 28-36.
In the September/October '07 issue pages 72-73 they had removed the springs.
In their situation it did not work out when installed in an SOA. Just a heads up on one case.
Old Jan 5, 2009 | 01:45 PM
Swansen's Avatar
pages 28-36.
Interesting, i'll have to look at that, thanks for the info... and i now have to bite my tongue.
Old Jan 5, 2009 | 01:56 PM
drew303's Avatar
pages 28-36.
I betcha it's because when you run them under the axle the theres no torqueing of the entire spring pack because the first spring in the pack has the eyes, which would be directly connected to the axle versa if you install them ontop of the axle (like our trucks, fjs etc) then your putting the contact point on the outer spring which might cause the spring pack to break or move excessively seeing as how the design has them spaced apart.
maybe if they made a pack with the eye spring on the bottom vs the top, for a SOA application?
Old Jan 5, 2009 | 02:42 PM
Swansen's Avatar
mmm, that makes a lot of sense, and i bet thats it the problem.
Old Jan 5, 2009 | 03:11 PM
dropzone's Avatar
Fossilized
they had even tried adding a traction bar, but no help
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
