Oil Pressure
Old Apr 4, 2018 | 02:34 PM
Cbrown83's Avatar
Oil Pressure
I've got a pretty simple question. What is the normal oil pressure for a 22re at cold idle and warm idle? I bought new mechanical gauges for my 87 pickup auto and the oil pressure gauge is reading 75psi at cold idle. That seems high to me. Any info would be appreciated. Thanks.
Old Apr 4, 2018 | 04:46 PM
akwheeler's Avatar
There is no such thing as a simple question here!!
75 psi is quite high, what does it run when warm? How long have you owned it? could you post a picture?
Old Apr 4, 2018 | 07:20 PM
Cbrown83's Avatar
It usually runs in the 60's went warm. I've had this truck almost 10 years and recently have done a complete rebuild.
Old Apr 5, 2018 | 11:07 AM
Co_94_PU's Avatar
Is it a steady 60-75 psi, or does it overshoot when revved?
Old Apr 5, 2018 | 11:12 AM
Cbrown83's Avatar
The pressure rises when reved.
Old Apr 5, 2018 | 12:14 PM
Co_94_PU's Avatar
But does it overshoot, like for example 100-125psi at 3000 rpms..
What filter are you using, does it have an anti drain back valve, does it have a bypass, have you changed it since the initial startup and if so did you cut it open and inspect it for debris?
Old Apr 5, 2018 | 12:19 PM
akwheeler's Avatar
Not running 90 weight in your engine are you? when was your last oil change? do you have a buddy with a gauge you can check this against?
Old Apr 5, 2018 | 12:24 PM
Co_94_PU's Avatar
Oil pump relief valve
The FSM doesn't give any details on this in regards to inspection..
It might be worth checking the valve actually moves inside the pump housing.
... Your oil weight will have some bearing on the pressure, as well the climate.
I wouldn't worry to much about high cold pressure alone. As you see in the chart above around 70psi is a good result.
I would keep in mind with a tight tolerance engine high revolution could push open the oil bypass and that this is something you should avoid causing to happen.
Old Jun 14, 2023 | 05:32 PM
Discombobulated's Avatar
Dude, why are you bumping old threads and copying and pasting another users reply? You are making threads confusing and weird…..
Old Jun 15, 2023 | 02:32 PM
akwheeler's Avatar
5 year old thread, original poster hasn't been active on this site in 4 years, and you took the words right out of my mouth.
Old Jul 13, 2023 | 03:36 PM
jeremy harp's Avatar
how often do you change oil ?
85triz
10
Nov 3, 2009 01:36 PM
Gsull
Sep 25, 2009 05:27 PM
the_supernerd
Dec 2, 2007 05:21 PM
ekim121
Mar 7, 2005 05:24 AM
Whitey
Aug 17, 2002 07:01 AM
