My To-Do List just keeps growing...
Old Dec 5, 2006 | 09:46 AM
  #41
bamachem's Avatar
got a panhard rod from sonoransteel.com and new rear shocks from the dealer. those are now on.
got (4) new warn solenoids to rebuild the control box from scratch. the old ones will be spares. i'll relocate the box with some heavy-gauge wiring to the firewall area while i'm at it.
ordered the timing belt, water pump, cam seals, crank seal, and assorted other stuff like belts etc. bought a 2nd gen supercharger complete with a 7th injector kit to install for a little more ummph. i have a used valve body with solenoids on the way ($20 shipped) that will get the full IPT treatments.
that should keep me busy for a while and make this thing fun to DD in my 120-mile daily commute again.
Old Dec 5, 2006 | 10:38 AM
  #42
amgraham's Avatar
Well, since this has been resurrected (not in any order):
Soon:
Fix several broken/stripped bolts (including the crossthreaded and broken blind nut on my front bumper/skid mount and a few for the top and rollbar)
Finishing touches on my Budbuilt skids
Make new brackets and install my free Integra seats
Fully clean truck inside and out (it's been awhile)
Extend rear diff breather further
Front brake pads
Adjust T-bars again
Replace relay for my Hellas and wire switch
Get a new rear wiper blade (nobody seems to stock them for the 1st gen)
Remove stock spare tire carrier
Roof Rack and light mounts of some sort
Sliders
Replace Firestik spring with stronger one
Future:
Total Chaos Caddy 2 Kit
33x10.50 15 BFG ATs
New rear springs and relocated shocks
Redone interior side panels with better insulation and built in subs and component speakers
Custom rear bumper and tire carrier (I'm talking plans over with Independent4x)
New exhaust system with header
Built 22R-E, possible turbo
Rebuild trans (or install stronger one based on new motor power output)
4.7:1 T-case gears
Electric fan
Window tint and black out rear side windows
Old Dec 5, 2006 | 05:38 PM
  #43
paxil4x4's Avatar
Drama Queen/Banned
My list:
With in the next two months.
New Battery
Replace valve cover gasket
Change F&R diff oil and trans oil
Install carpet kit
Locate a inclinometer (dashmount)
Line X the bed
Install Hella H4's
Replace timing chain, fan clutch, cover, guides, water pump, oil pan gasket etc as a percaution.
By next summer
Locate a complete powersteering unit
Install A/C
Rebuild front axle completely new seals bearing etc
Change all the rubber fuel lines
Junk the chrome rear bumper and replace with a black one
Install my 3 spoke late model Toyota truck wheels with new tires
Bilstein Shocks on all 4
End of next summer
Finish undercoating the truck and waxoyl all the inner body cavities
Rustoluem the frame.
Old Dec 18, 2006 | 06:16 AM
  #44
bamachem's Avatar
yesterday:
changed out steering rack bushings - ahhhh, nice and TIGHT steering now!
replaced all 4 solenoids in winch control box - trashed one and kept 3 for spares
greased/lubed sway bar frame bushings - sQuEaKy no more!
changed oil/filter - 'bout that time...
fixed horn - had a loose connection on one of them
adjusted front bumper - torqued down w/ a 18" cheater bar - that should hold now!
Old Jan 24, 2007 | 06:08 PM
  #45
bamachem's Avatar
runner is now in the shop and tomorrow will get:
timing belt
tensioner
water pump
crank seal
cam seals
accessory belts
i had all intentions of doing it myself, but i can't find the time. i got the parts a while back from strap22 for $204, and now i'm paying $200 labor for the install. not bad at all.
Old Mar 13, 2007 | 01:57 PM
  #46
horunner's Avatar
i know its a little late for this but for all you guys who posted what youve completed could you put some prices next to what youve done i know i need to fix things before they break so im trying to decide what the best fix for my buck is
thanks alot
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
SpookyMulder
Nov 4, 2015 11:56 AM
ktm192k
Oct 1, 2015 08:47 AM
