My To-Do List just keeps growing...
Old Oct 16, 2006 | 10:53 AM
bamachem's Avatar
and growing and growing ...
Rear Axle Seal R&R - intermittent leak - DONE, it was actually the rear Brake Hydraulic Cylinder leaking.
Resurface Rear Drums - needs to be done anyway - DONE
Rear Brake Shoes R&R - need to be replaced due to age (8 years and 155k miles) and leak damage- DONE
Front Struts/Coils Assembly - blue tokicos and 4wd trd coils awaiting assembly - DONE
Front Coils Install - then sell off OME N91s/TRD Coils/Topouts assembled setup - DONE
Rear Links Install - DONE
Rear Coils Install - DONE
Replace PS CV w/ new - DONE
Replace DS CV w/ new - DONE
Steering Rack Bushings R&R - severely degraded - DONE
Rear Adjustable Panhard Rod Install - DONE
Rear Shocks Install - sell off OME N86's - DONE
Change Oil & Filter - Mobil 1 Extended Drain w/ 1995 Ford Taurus V6 Filter - DONE
Timing Belt, Water Pump, & Acc Belts - DONE
Re-align Front Bumper - slipped on mounting brackets/bolts last time i winched - DONE
Repair Winch Solenoid that overheats - 4 new solenoids in hand - DONE
Change Front Diff Fluid - Mobil 1 / Shell Rotella - DONE
Change Rear Diff Fluid - Mobil 1 / Shell Rotella - DONE
Drain & Refill Trans Pan - Mobil 1 - DONE
Drain & Refill XF Case - Mobil 1 / Shell Rotella - DONE
Repair CB Hook-up - resolder connections on mic
Remove ARB Compressor - sell off
Install New Compressor - ExtremeAir 100% duty cycle
Cut Off Sliders, Re-weld Sliders w/ Scab Plates - locate 1" higher for BL since initial install
Cut off Rear Bumper Brackets & weld on new HD Rear Bumper Brackets & Drill - stiffness increase & design change - 4"x4"x1/4" angle on-hand
Drill Bumper for Carrier Latch Pin & Weld On - safety pin for double-security and positive latch on closing
Prep Rear Bumper & Paint - clean up remaining welds, sand, prime, paint, clear, reinstall on runner
Trim & Weld Upper Front Arms for clearance - 305's just barely touch at full droop
what does your TO-DO list look like? not necessarily mods, but what do you need to do to "fix" stuff on your toyota?
Old Oct 16, 2006 | 10:58 AM
flyans's Avatar
It's too long to post...
Old Oct 16, 2006 | 11:03 AM
Localmotion's Avatar
try to get new tires
drain/refill t-case
drain/refill front diff
drain/refill rear diff
replace D/F upper ball joint
install Body lift
install 3/8 spacer with extended studs
replace steering rack bushings
install new TJM cb arial bracket (from J.Burtman)
re-wire Lightforces
Old Oct 16, 2006 | 11:05 AM
paddlenbike's Avatar
Mine's not too bad:
change the oil
install new Tundra/OME suspension (and panhard bar, extended brake lines, etc.)
Have new tires mounted and balanced
Remove mudflaps since they will rub with the larger tires
Weld something in between the bars of the sliders to keep the rock chips at bay
switchable DRLs
Old Oct 16, 2006 | 11:06 AM
EWAYota's Avatar
Just ordered:
Timing Chain Set
Full Gasket Set
Timing Cover
Water Pump
Oil Pump
Need to get new bolts for Timing Cover
Put engine back together
Replace tierods
Change front and rear diff. fluids
Change xfer case fluids
Flush transmission
Take the truck in for Recall once its running
Possibly change alternator
Need new battery
I'm sure there's more, but I haven't driven it in so long, can't remember what all needs to be done besides just getting it running!
Old Oct 16, 2006 | 11:11 AM
hillbilly's Avatar
drain/fill t-case
drain/fill front diff
drain/fill rear diff
drain/fill tranny
install a System 7 from Schaefer (as soon as I save up $$$ to actually buy it)
Old Oct 16, 2006 | 11:17 AM
X-AWDriver's Avatar
Thankfully mone is short
Oil change
gear box fluids changed
New wipers for winter
Old Oct 16, 2006 | 11:22 AM
saulgoode's Avatar
The need to do list:
change brake rotors and pads or upgrade to tundra brakes
Change tranny filter
New battery
grease driveshaft bushings
The want to do list:
Tundra/OME lift
285 tires and rims to accomodate
put on brushguard that's been sitting in my garage
hella lights
rear diff. locker
just off the top of my head
Old Oct 16, 2006 | 11:29 AM
garrett1478's Avatar
short term:
install/wire autodim mirror
install/wire 99+ bezel/center dash piece
wash/wax
long term:
way too much to write....
Old Oct 16, 2006 | 11:38 AM
gregbreakseverything's Avatar
Install Tundra/OME lift
Check brakes, probobly replace pads, deffinatly needs rotors.
Change oil
Install rear diff breather extension
Buy winter tires
Fix windshield washer fluid sensor
Buy and install block heater
Buy and install Car alarm/Starter
Get window scraper
Old Oct 16, 2006 | 12:15 PM
NPE701's Avatar
Why is that? And how much are you selling it for?
Old Oct 16, 2006 | 12:56 PM
waskillywabbit's Avatar
You want the whole list or just the top 50?
In order of priority
Family
Build 70+ feet of 6 foot tall privacy fence with gate
Install 150+ hog wire fence around property line
Finish building the boys’ “castle”
Full-timer
Work 60+ hours per week
WabFab Off-Road
Fabricate 20+ slider adapters
Assemble a set of quick discos
Assemble a bikini kit
Design/print business stickers/t-shirts
Make preparations for SE4RJ4 www.se4rj.com/bbs
Project “Wabbit” 85 4Runner
Remove OEM steering – sell IFS box
R/R steering shaft upper u-joint
Custom front windshield sticker
Tear down front axle – again
Remove front shocks
Remove front driveshaft to make welding easier (rotate axle)
Weld on Trail Gear knuckle gussets – gusset and shock mount in one
Reassemble front axle
Install full hydro steering – Performance Off-Road Systems
Remove and drain OEM gas tank – it is FULL
Relocate rear shocks to OEM / \ setup
Fab up mounting area for fuel fell
Install custom fuel cell and components
Plumb fuel lines
Tube front clip – remove sheet metal back to firewall
Rework core support
Narrow hood
Install electric fan and variable speed controller
Relocate battery and electrical to inside cab
Reinstall triple battery system
Rewire custom dash w/ Autometer gauges
Build/refurbish dual cases, 4.7 gears, Longfield chromo output shaft, Marlin twin stick
Install dual cases Budbuilt cross member w/ skid
Fabricate custom exo cage incorporating front stinger and rear fold down tire carrier (needed weight on rear end)
Fabricate mounts and install rock crawling seats w/ 5 point harnesses
Install some kick ass tunes
Paint cab w/ some bling
Fabricate (2) spare tire mounts for tow trailer – trailer spare, 85 spare
All I can remember for now...as that is the short list.
Old Oct 16, 2006 | 01:08 PM
ROOFGOOF's Avatar
Clean up my American Mastiffs poop in the yard. (my wife demands it) #1 priority!!!
4runner ---
Install ProComp 4inch front lift
Extend front and rear brake lines
Install LC Coils
Install 1 or 1.5 rear coil spacer ??? TBD
Install new rear shocks ??? TBD
Install new adj. pan hard bar
Find out why my check engine light is on
Oil change in about 1 month
wax job before winter
and go wheeling !!!!
Old Oct 16, 2006 | 02:11 PM
neliconcept's Avatar
my list
locate 01-02 4wd tranny
locate tcase
locate waggy d44 axle
save up for 3 link allpro SAS setup
fix my stupid rear windsheild wiper
get bodylift on
fix my rear panhard bar
CLEAN CLEAN CLEAN,, it needs it bad on the inside
build my sleeper platform for the back
nothing really needs to be fixed
i think thats about it for now
Old Oct 16, 2006 | 02:33 PM
fireteacher's Avatar
x2 on the dumb rear wiper! it barely gets half the window
rocket's Avatar
Happy Birthday bamachem!
Need to-do:
Get my "new" Nitto tires put on
Install Budbuilt skid plate
Change f/r diff fluid
Change tranny fluid
Flush P/S fluid
Flush radiator fluid
Install my new stereo system (Sony deck, Polk f/r speakers, Alpine Type-R sub, & two Alpine amps)
Install new Cobra 18 WX ST II
Replace battery
Purchase an alarm system
Wax
Buy another Yota for rock crawling purposes only.
Old Oct 16, 2006 | 04:26 PM
petros's Avatar
Mine's pretty short:
Oil change
Wash/clay bar/wax/vacuum before winter
Get Husky liner or equivelent for rear before ski season
Put snowboard rack on when the season starts
Get remote lock/unlock/start as soon as employee discount kicks in at Best Buy
Pay off 4Runner...
And the stuff that will probably never ever get done, but I've identified them as things that I want done but once I come up with the money they are instantly at the bottom of my list:
Get roof and hood repainted due to negligent previous owner (hood is not really noticable, and I never look at the roof anyway. Easy to not care about.)
Get parts for and install Tacoma Whip Antenna Mod (I don't listen to the radio at all really, but my current antenna is broken)
Get windows tinted a bit
Old Oct 16, 2006 | 04:34 PM
bamachem's Avatar
It's the compressor for the lockers. No harness, no switch, no pressure switch. Just the compressor - pretty much a replacement for someone who already has one. $100
Originally Posted by rocket
Happy Birthday bamachem! ...
THANKS!
Old Oct 16, 2006 | 04:53 PM
iruny4wd's Avatar
-every fluid in my truck needs to be changed
-a few wheel studs need to be replaced
-gotta take care of some bed rust
-gotta make some kick panel enclosures for my speakers which are just laying on the floor right now
-my engine is on it's last leg so I should start getting stuff ready for my swap (4.3L chevy)
-My tires are getting pretty bald, need to get some new ones
Old Oct 16, 2006 | 05:11 PM
Bob_98SR5's Avatar
re-installing oil relocator kit and motor oil
changing spark plugs
cleaning maf
installing vaccuum pressure gauge
changing sway bar and steering rack bushings
change oil
change all gear fluids (diff, tsf case, etc)
lube zerks
new tires
and...install my elocker! thanks to tstango for the great deal on the bare rear axle that should get here by friday. i hope
bob
