My To-Do List just keeps growing...
Old Oct 16, 2006 | 05:30 PM
fireteacher's Avatar
bob, get your tranny fixed?
Old Oct 16, 2006 | 05:39 PM
1989toy4wd's Avatar
Engine rebuild (burning oil 1/2 quart every 3-5 days)
transfer case oil change
front diff oil change
rear diff oil change
transmission fluid changed (just had rebuilt, but want synthetic in there)
Done in past year:
new brakes
new o2 sensor
new catalytic converter
new tires
new fuel filter
new spark plugs
new SP wires
new dist. cap
new rotor
rebuilt trans
new clutch
new pressure plate
new throwout bearing
2 new batteries (one was crap)
...and there is probably more that I forgot
Old Oct 16, 2006 | 05:46 PM
dragr1's Avatar
Install front Tokico's and Tundra's-sitting in garage
Install cruiser coils or mystery coils in the rear-sitting in garage
Make bigger mount plates for sliders and remount sliders higher-currently bent
Figure out and fix what part of my front bumper is bent from slickrock
Replace ps headlight-broke one mount screw on slickrock
Rework skidplates-bent and rattle
Make new skidplate for gas tank-mine is absolute scrap metal
Figure out how to keep the driveshaft from hitting the gas tank skid
Armor several other places underneath
Weld shut and repaint conferr rack
Purchase and install synthetic winch rope
Redo cargo box so it does not open from the top-access all from back
35's????????????????
Figure out what I want as onboard air setup-already have the compressor
I'm sure there is other stuff that I have forgotten
Old Oct 16, 2006 | 06:11 PM
Bob_98SR5's Avatar
fire,
nope. i am 'living with it' for now. the mechanic guy said he would pay for another diagnosis at a toyota dealership nearby and pay for a rental car for a day. good that he is making the effort, but i may not take him up on it. what would you think the dealer would say?
dealer tech: "hmm....yeah, definitely the tranny"
but thanks for asking
bob
Old Oct 16, 2006 | 06:25 PM
  #25
CJM's Avatar
CJM
Things I need:
New shocks, old ones are worn out
New rotors and brakes just done
Figure out what the heck is making a rattling noise at 50mph
Things I want:
That list is to long..
Old Oct 16, 2006 | 08:54 PM
  #26
d0ubledown's Avatar
just did
-4 freaking CV boots
-new front swaybar bushings
-replaced pwr antenna mast that snapped
need to do
-tranny flush
-coolant flush
-brake fluid flush + SS lines
-fix tcase harmonic damper
-get rear bumper made & maybe new skid
just did diff/case fluids 10K ago..so next oil change im probably gonna go full synth n see how it works.
wish to do
-4.88's & 35" MT/R's
-front ARB & manual hubs
must do within next 6-8 years or at least before i die..
-swap the front with a d44 or 80 axle...3 linked.
Old Oct 17, 2006 | 04:13 PM
  #27
StretchASU's Avatar
Short list
Upgrade front rotors
Install Tundra/OEM lift
Diff breather mod
285/75/16's of some sort
Old Oct 17, 2006 | 04:29 PM
  #28
90runnner's Avatar
try to get new tires
drain/refill t-case
drain/refill front diff
drain/refill rear diff
replace D/F upper ball joint
install Body lift
install 3/8 spacer with extended studs
replace steering rack bushings
install new TJM cb arial bracket (from J.Burtman)
re-wire Lightforces
well matt, if you get your butt down here we'll take care of it sheesh
Old Oct 17, 2006 | 05:12 PM
  #29
Adam F's Avatar
My current list is as follows....
Timing belt
water pump
water neck idler
flush coolant
thermostat
new fan shroud
valve cover gaskets
helicoil 2 spark plug holes
install new (used) fuel injectors
pcv and grommet
clean out intake mainifold and EGR system
I've got the timing belt off, and today I got the valve cover gaskets sealed, and the 2 spark plug holes helicoil'ed. Next week I'll wrap up the rest of the things.
After that, I need a new front drive shaft, and move my front axle forward. Oh, and make some spring retainers for my rear TJ springs.
And then, I need to finish up my OBA/horn install. I have the tank mounted, but thats as far as I got.
Then, I'm going to do a 2 tone paint job using some rattle can bedliner on the quarters and fenders. Then probably rip out the carpet in the cargo area and spray it with some more rattle can bedliner.
Then, who knows. Front locker? 5.29's? Who knows.
Old Oct 17, 2006 | 05:44 PM
  #30
slosurfer's Avatar
get sliders welded on
oil change
timing belt
water pump
auto tranny flush and fill w/synthetic
diffs drained, fill w/ synthetic add diff breathers
ISR mod
learn to weld
fab front and rear bumpers
sas
5.29's
lockers
get new taco dcab for wife so she the runner is no longer dd
get rid of scratchs and wax it
get seat covers
get husky floor liners
make rear cargo box
get engel fridge
finish my m416 trailer
wheel it as much as I can
oh yea, dual cases somewhere in there
Old Oct 17, 2006 | 05:49 PM
  #31
calrockx's Avatar
my list:
oil change.
Old Oct 17, 2006 | 05:56 PM
  #32
HarrisonP's Avatar
R&P bushings
Rear LC tokico shocks
2 Extra BL brackets from 4Crawler
Tranny fluid change
Transfer case fluid
Fix Temp Gauge
Replace driver side cv boots
Start building my rear bumper (already have the steel)
Redo my sliders, I have them mounted too high
Timing belt/water pump
Adjust valves
Finish building cargo box
Add supports to sides of TJM
There is more just can't think of it off the top of my head
Old Oct 17, 2006 | 06:17 PM
  #33
slosurfer's Avatar
Originally Posted by calrockx
my list:
oil change.
bastard!
Old Oct 21, 2006 | 04:46 AM
  #34
bamachem's Avatar
OK...
I got the rear brake pads on the cruiser changed, then started on the runner.
I got the passenger side drum off after quite a bit of effort and my elequent use of my 4-letter word vocabulary. After getting it off, I began to take the shoes off when I was squirted with brake fluid from a pinhole in the brake hydraulic cylinder piston boot. NICE! At least it wasn't an axle seal like we first thought. I got a Reman cylinder and put it on, replaced the shoes, then bled the system out. I then got started on the other side. Nice and dry, but hard as heck to get off. After about 40 minutes, it finally relinquished and I got things rebuilt and back on about 30 minutes later.
I used OEM shoes, and a drum rebuild kit from Advance that had all new springs, clips, etc. That was a good buy at only $15. The Reman hydraulic cylinder was another $15 from the same place (at 8pm so dealer wasn't even an option and neither was a rebuild kit for the OEM one).
So, 1, 2, & 3 are now done. Time for 4 & 5.
Old Nov 9, 2006 | 03:11 PM
  #35
bamachem's Avatar
more done today. my son was home w/ strep and pretty much laid on the couch and rested. i had the front coils mounted on the tokicos, and while i waited on them, i installed the new LC rear coils and the sonoran steel lower links. after that was done, we went and picked up the front assemblies. i had them on in about an hour.
i still have to get some LC rear shocks and put on the adjustable panhard bar as soon as it gets here. then i should be done w/ the suspension...
pics of the process and the new ride height will be up shortly...
Old Nov 9, 2006 | 03:21 PM
  #36
dragr1's Avatar
Dang, I still haven't donw anything-you're welcome to come work on my list.
Old Nov 10, 2006 | 05:06 AM
  #37
jwbehm's Avatar
My list:
-Get sliders welded
-Get lockright installed
-Replace one inner cv boot (maybe just the cv clamp?)
-wire CB antenna (currently just a PA )
-Sand/ repaint hitch
-Buy sandbags to settle my LC coils
Old Nov 10, 2006 | 05:26 AM
  #38
bamachem's Avatar
oh, and i have to add a CV rebuild to the list. i have torn inners on BOTH of the CV's that are currently on the runner. i'm thinking of getting my OEM CV's rebuilt, then cryo'd and reinstalling them...
Old Nov 11, 2006 | 04:47 PM
  #39
bamachem's Avatar
lol... another update... i had some time this afternoon, so i swapped the coils to the correct sides :pat: YY on driver and YB on passenger. i also rotated the tires, and replaced both CV's w/ new ones. both of the ones that i took off were my "spares" and have both developed inner boot leaks in the last few months. now i have those two to repair along w/ two more that need to be rebuilt... lol..
Old Nov 11, 2006 | 07:19 PM
  #40
dragr1's Avatar
Wow, Mr. Git R Done now! Shouldn't you be watching the Vols or something?
