Just got Amer Racing steelies - need new lug nuts?
Old May 8, 2006 | 06:38 PM
tc's Avatar
tc
Got a set of AR767 steelies mounted with 34x9.50 SuperSwamper TSL's to use for 'wheelin'. Looks like there will need to be some "rub remediation" techniques employed due to the 4" backspacing (although this makes the edge of the tire come out the same as the 33x10.50 "road" tires)
The current wheels are the double-four spoke SR5 alloys, and have the lug nuts with the little extension/sleeve below the washer.
For the steel rims, do I need new lug nuts that allow the washer to get up flush to the rim?
Old May 8, 2006 | 06:41 PM
Tanto's Avatar
I'm not familiar with the wheels your talking about but if there is a bevel around the edges of the lug holes in the wheel, then you need the acorn-style nuts.
Old May 8, 2006 | 06:45 PM
slosurfer's Avatar
Tanto is correct, you will need the acorn style nuts. The tire store had the basic ones for 1.95, but I didn't feel like spending 50 bucks for my offroad set. He let me take home the bucket of used nuts and I was able to find enough to use. They don't all match, but the fronts match and the rears match, plus they were free.
~Chris
Old May 8, 2006 | 06:46 PM
tc's Avatar
tc
Yes, the holes are chamfered a bit. Are the acorn style different than what I have?
Old May 8, 2006 | 06:52 PM
Tanto's Avatar
So I take it that you're saying that there is about a 45 degree groove around the holes in your wheels, right? The acorn-style nuts have a matching groove that will mate perfectly with the groove on your wheel.
Any other lug has a sort of sleeve that has a washer stuck to the lugs.
Old May 8, 2006 | 06:55 PM
Tanto's Avatar
This is a shot of a NON acorn -style nut (note the washer)
Old May 8, 2006 | 07:15 PM
slosurfer's Avatar
Here is an example of an acorn style lug nut:
http://cgi.ebay.com/ebaymotors/Black...spagenameZWDVW
Old May 8, 2006 | 07:17 PM
slosurfer's Avatar
tc, I think you are going to have to change your sig. "stop with the mods, and get on the trail" It sounds like you have been doing quite a lot lately.
Old May 9, 2006 | 04:13 PM
tc's Avatar
tc
Gotcha - that's what I have. Note the chamfer on the bottom ...
As for the sig comment ... maybe I need to change it to mod during the week, wheel on the weekends!
Once I get these wheels to fit, the mods will definitely be done for quite a while!
Old May 9, 2006 | 09:10 PM
TechWrench's Avatar
The chamfer on the bottom of those lug nuts is probably for ease of insertion into the recess on the alloy wheels. Acorn lug nuts usually have the chamfer all the way out to the sides of the nut. The reason for the difference is most alloys are 'hub' centric aligned, which means the wheel is centered on the hub when mounted. Most steel wheels are 'lug' centric, which means the lug nuts actually center the wheels on the lug studs and not the hub.
Old May 10, 2006 | 03:56 AM
waskillywabbit's Avatar
Black steelie lug nuts at Wheeler's Off-Road for $1 each.
HiLuxer
Jan 6, 2016 11:34 AM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Cycles
Sep 29, 2015 06:37 AM
