HELP!! truck dying when i push on the gas...
Old Aug 10, 2009 | 04:06 PM
mudman6060's Avatar
Unhappy HELP!! truck dying when i push on the gas...
So no one at all knows what in the heck is wrong with my truck. I have an 85 sr5 pickup xtra cab 4x4 with and 22RE 5 apeed. What the truck is doing is.....when you first try and start it...it won't start. After a few tries it'll finally start and idle just fine....no knocks or rough idling. BUT....when you push the throttle quick, instead of reving up...it just bout dies (goes down to round 100 rpms or so) or it cuts off. BUT...if you rev it up SLOWLY it revs up just fine. I've replaced the throttle position sensor and all the vaccum lines I could fine. If anyone has any idea at all on what you think it might be or you know of any way to fix this please let me know. thanks
Old Aug 10, 2009 | 04:08 PM
mudman6060's Avatar
oh and I've also replaced the fuel pump, fuel filter, and main relay
Old Aug 10, 2009 | 04:35 PM
Team420's Avatar
got a plugged cat or muffler? Disconnect them, and try again....If same problem...u ruled it out.
Old Aug 10, 2009 | 04:44 PM
mudman6060's Avatar
right now it's straight headers....no cat or nothin :/ thanks though
Old Aug 10, 2009 | 06:29 PM
mudman6060's Avatar
seriously...if anyone's got any ideas at all throw em out there....PLEASE lol
Old Aug 11, 2009 | 10:09 AM
Team420's Avatar
Spark? How are your plug wires, dizzy cap, and rotor? Coil & Igniter? Thats the next place I'd start looking.
Old Aug 11, 2009 | 10:31 AM
Lumpy's Avatar
What about the AFM??? Is the flapper stuck?
Old Aug 11, 2009 | 11:14 AM
ozziesironmanoffroad's Avatar
hows the tps? mine would do the same thing til i replaced the tps. also check the iac
Old Aug 11, 2009 | 02:44 PM
mudman6060's Avatar
team420i've replaced the plugs wires, ect. haven't checked anything with the coil or nothin so i'll have to do that.
lumpy-the flapper is not stuck on the air flow meter (figured it had somethin to do with the afm so i took it off and everything looked fine with it. is there anything else i can do to check that the afm is workin properly???
ozzies- if yer talkin bout the throttle position sensor i just replaced that...all that did was correct the idle. where exactly is is idle air control valve?? i THINK it's right under the throttle body but idk???
THANKS
Old Aug 11, 2009 | 02:53 PM
pretty sure thats where it is....
Old Aug 12, 2009 | 01:39 PM
mudman6060's Avatar
Is this the iac valve???
Attached Thumbnails HELP!! truck dying when i push on the gas...-0812091647a.jpg-2.jpg
Old Aug 12, 2009 | 01:44 PM
mudman6060's Avatar
also....does anyone know what these 2 things are??? i'm thinkin the one that's got the lil white screw on top that's connected to the intake manifold has somethin to do with some vacuum adjustment...anyone know???
Attached Thumbnails HELP!! truck dying when i push on the gas...-0812091646b.jpg-2.jpg   HELP!! truck dying when i push on the gas...-0812091649b.jpg-2.jpg
Old Aug 12, 2009 | 03:03 PM
Lumpy's Avatar
Well I think the white screw thingy is for the AC idle up...If i'm not mistaken.
Old Aug 12, 2009 | 03:20 PM
mudman6060's Avatar
well if that's so it won't bother nothin...i have no ac at all lol
and i figured out what the other thing is (but Correct me if i'm wrong)...it's an EGR vacuum modulator....think it has somethin to do with makin sure the engine burns all the fuel or somthin like that.
Old Aug 12, 2009 | 03:35 PM
1989toy4wd's Avatar
Get a haynes manual, there is a way to diagnose the VAF...also check your alternator, believe it or not mine did this once too and the alternator was going out...it would supply enough power at idle but not enough at higher RPMS.
I think its your VAF though!
Old Aug 12, 2009 | 05:55 PM
4Crawler's Avatar
Try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
And check carefully for any cracks in the rubber sections of the air intake, between the AFM and the throttle body. That will show the same symptoms.
Old Aug 13, 2009 | 12:48 PM
mudman6060's Avatar
1989toy4wd-well like i said...the truck starts spittin and sputterin and startin to die if i tap the gas quick and hard. if i ease on the gas it'll rev up to 5000 just fine. it also does it if i'm drivin....i think it's when i'm tryin to accelerate and i'm pushin the gas down harder. it's almost like it's actin like it's confused.
4crawler- the fuel pump is workin fine...when i replaced it we disconnected the lines after the fuel filter and turned the key to on and gas just poured out.
Old Aug 13, 2009 | 12:51 PM
4Crawler's Avatar
But do you know if the pump is working when you mash the gas pedal? The test jumper will ensure power to the pump at all times. If that helps, then check your Air Flow Meter, might be a dropout in the Fc circuit:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
And check the Throttle Position Sensor:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Aug 13, 2009 | 09:04 PM
mudman6060's Avatar
thanks for those links...my buddy's got an ohm meter....so we'll try it and see what we can find out
Old Sep 1, 2009 | 05:53 AM
mudman60's Avatar
well my buddy still hasn't brought his ohm meter from work. BUT...now my truck won't even start (well it will but you have to let it sit for a lil bit then it'll start then just die after bout a second)...but it will start and run for a sec off of throttle body cleaner. I think what it really might've been all along was we never did clean out the gas tank when we replaced the fuel pump n all. SO...does anyone know good way to clean out a gas tank without buyin a new one??????????
