HELP!! truck dying when i push on the gas...
Old Sep 16, 2009 | 04:37 AM
Snipesrock's Avatar
Well, use 10% ethenol gas and shake it around a lot, then empty it. There is also cleaning stuff you can buy. Same thing happened to my car when I first bought it and I ended up replacing my gas tank.
Old Sep 16, 2009 | 05:19 AM
desertcamper67's Avatar
I haven't read all the replies but have you checked for a vaccuum leak by spraying carb cleaner around your intake while its running to see if anything changes?
Old Sep 16, 2009 | 05:31 AM
jrohland's Avatar
Sounds like the carb to me
You did not say if this is injected or carborated. However, it sound like the accelerator pump is bad. That is the classic symptom.
jrohland
Old Sep 16, 2009 | 05:36 AM
hjkmotor's Avatar
check the timing, i can see it doing that if the timing is a little off.
Old Sep 16, 2009 | 06:55 AM
  #25
jpmountainboy's Avatar
If you dont have a volt meter...did you not use one to adjust you new TPS when you put it in???
If not...there you go.
Old Sep 16, 2009 | 09:00 AM
  #26
Jryals1129's Avatar
i have 85 4runner did the same thing a few years back.I change the whole intake system and it fixed it. Now it is doing it again i think water is getting into my ECU.You can try to chage the ECU it might fix it good luck
Old Sep 16, 2009 | 09:30 AM
  #27
ramtime's Avatar
Start with the timing. If you changed the cap and rotor like you said, you should start here.
Old Oct 4, 2009 | 12:03 AM
  #28
81 yota 4x4's Avatar
DONT PUNCH THE THROTTLE!! you'll be fine.
Old Oct 6, 2009 | 05:53 PM
  #29
mudman6060's Avatar
well we're gonna try and drop the gas tank and clean it, then replace the fuel pump and prolly the filter too and see if that works. I know it's a fuel dilevery problem bc it'll run off of thorttle body cleaner or startin fluid.
Old Oct 6, 2009 | 06:13 PM
  #30
weaselman's Avatar
you make no sense?
you said you have replaced the fuel pump. and gas "poured out" after the filter??
why would u change it again??
Old Oct 6, 2009 | 06:33 PM
  #31
heresjohnny's Avatar
my truck did this it was the the air flow meter
stupid mud...
Old Oct 9, 2009 | 09:35 AM
  #32
mudman6060's Avatar
ok....so NOW i got it runnin...one of the fuel lines was leakin out fuel. at first it was runnin fine...but when i took it on a test drive it started just spittin and sputterin. sooooooo.....now i gotta figure out what THIS problem is now. bad thing is....it can be one of a bunch of things lol
Old Oct 9, 2009 | 09:40 AM
  #33
91Toyota's Avatar
how do you not know its leaking gas? Can you not smell/see gas???
Old Oct 9, 2009 | 09:55 AM
  #34
JFCruiser's Avatar
possibly a vacuum leakage can cause such issues. But not sure exactly which part
Old Oct 11, 2009 | 12:09 AM
  #35
mudman6060's Avatar
well...bout the vacuum leak...i replaced ALL of the lines i could find with new hoses.
BUT.....i got it runnin RIGHT turns out ALL it was was a bad spark plug...sometimes i really hate life lol. so now all i gotta do is get the clutch workin right and she'll be on the road
Old Oct 12, 2009 | 08:20 AM
  #36
JFCruiser's Avatar
Thats good to know that you fixed it
Only problem for me now is that i just bought new OEM vacuum hoses from this site http://toyotapartszone.com but the only problem is that my car is still a little shaky. I assume its electrical currents not flowing correctly. Any suggestions
Old Oct 12, 2009 | 08:32 AM
  #37
4Crawler's Avatar
Might make sure the TPS IDL-E2 setting is connect, if not you'll have a rough idle:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Oct 12, 2009 | 11:53 AM
  #38
94yodaPU's Avatar
I may be completely off base but I had a 79 cutlass that did the same thing and it was just due to a fowled spark plug.
Old Oct 13, 2009 | 08:33 AM
  #39
JFCruiser's Avatar
That was a beautiful write up wow lol
Ok im try to do that, seems a little complicated but ill try my best thanks for the feedback
ill get back to you guys asap
Old Oct 26, 2009 | 09:38 AM
  #40
mudman6060's Avatar
ok....anyone know a place i can get a CHEAP header from???? my header the pipe comin from the #2 and #3 cylinder somehow managed to break in half
sonic concepts
Aug 16, 2025 03:13 PM
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
ibayne
Jun 26, 2015 06:30 AM
slider417
Jun 22, 2015 10:18 AM
