Great tip for DIY security device/ignition kill
Old Jul 25, 2006 | 05:55 AM
nrgetic99's Avatar
Ok,
I am not going to give specific details in case the 'bad people' are surfing but I have two great tips that I checked last night.
1. Circuit opening relay.
I used this on my 93 and just did the same on my 98.
If you put a switch in the green/yellow wire (its a low voltage wire that is 5V and very low current) , the starter will not work and neither will the ignitiuon system. This realy prevents both the starter circuit and the ignition circuit from energizing.
Find this relay from your manual. Chase down the harness to a spot where you can cut in and then cover it back up with black insulating tape (ther are spots on the harness that have factory black wrap.
Wire in a hidden switch or an alarm operated relay.
Truck WILL not start if the supply in this line is interupted
2. Auto only
Shift interlock ECU.
You can cut the Green White wire and it works the same as having a stop lamp bulb out. You cannot shift out of Park.
Last night, I wired a switch to a pair of SPST relays. If I can find a DPDT relay, I will replace it and actually cut the circuit opening relay wire and the shift interlock wire and have them both operated via the relays and switch.
Once activated, truck won't start and cannot be shifted into neutral to roll it away.
Sorry for lack of specific detail but do your research, find a good location for you and its a 90 min job at best.
David
Old Jul 25, 2006 | 06:40 AM
Toyota Punk's Avatar
I like it! I remember hearing about the fuel pump wire and always wanted to do that. I like the idea of the shift ecu wire, nice one-two combo there!
Old Jul 25, 2006 | 06:52 AM
nrgetic99's Avatar
Well, I may or may not have the fuel pump wire cut...can't tell all my secrets !
Nice thing is, fuel pump relay ALSO will not energize without circuit opening relay.
David
Old Aug 4, 2007 | 02:32 PM
rayl82's Avatar
shifter loce bypass
in regards to the shifter lock any good thief knows if you turn the ket to the on pos you can shift into nutral and start the truck as long as you dont go into park you are good to go if i am wrong please correct me
Originally Posted by nrgetic99
Ok,
2. Auto only
David
XtraCab
Apr 12, 2020 05:25 AM
okamikai
Apr 30, 2018 10:19 PM
93toyoguy
Aug 2, 2015 07:41 PM
vanion2
Jul 29, 2015 06:17 PM
crashburnoveride
Jul 10, 2015 06:39 AM
