Getting Those Pesky Suction Cups to Actually Stick!
Old Aug 24, 2006 | 09:35 PM
ErikJeanna's Avatar
Talking Getting Those Pesky Suction Cups to Actually Stick!
I have a GPS that I choose to mount to my windshield. However, the weight of the GPS makes it so the suction cup falls off after a day or two. This is doubly annoying because not only does it set my alarm off, it opens my GPS to possible damage from the fall. I have looked on the web for some possible solutions, but some don't work and others don't suit my taste (hot gluing it). For those of you out there that have devices that are held by a suction cup to the windshield, you have probably shared in my frustration with this issue.
So, after playing around with different things around the house to try to make it stick better... I think I came up with a good one. So far, it has held for 2 full weeks now with no signs of coming off anytime soon.
OK, you take some normal household oil (Wesson/olive oil/etc) and put just the smallest drop on the suction cup. Spread it around with your finger. It might look like it's drying up, but it's not. Now, affix it to a clean section of your windshield. You will notice that it may slide around a bit. This is actually OK... better to position it EXACTLY where you want it. It should stick quite well after it "sets" and should wipe off with ease when you go to take it off.
If anyone has any other suggestions, please post them here.
Old Aug 24, 2006 | 09:37 PM
msw0085's Avatar
Good idea. My 8500 falls off alot in the extreme heat or (relative) extreme cold. I will give this a try.
Old Aug 24, 2006 | 10:13 PM
89macrunner's Avatar
licking the suction cup and applying it to a clean windshield should help also.
I used to put up the number at gas stations and the words up on a store sign.. that always helped
Old Aug 25, 2006 | 05:34 AM
midiwall's Avatar
I used a bit of silicone (plumber's GOOP rawks!) on the suction cup...
Old Aug 25, 2006 | 07:30 AM
ErikJeanna's Avatar
This is one of the methods that I tried that maybe worked for 2 days at best before coming down.
Old Aug 25, 2006 | 11:41 AM
SuaveGato's Avatar
I've used clear hardening silicone with great results... the silicone easily comes off when you want it to as well with a fingernail or razor blade etc.
good luck,
biGjOhn
Old Aug 25, 2006 | 12:38 PM
cackalak han's Avatar
I've used lotion in the past. Works pretty good. My V1 stays up with just spit, though.
Old Aug 25, 2006 | 02:48 PM
SpikeStrip's Avatar
Sound too much like Masterbation....
Old Aug 25, 2006 | 02:58 PM
Glenn's Avatar
I've never wanted my GPS on the windshield for two days, and never for two weeks. It seems like car-prowler bait to leave it on there when you aren't using it.
Old Aug 25, 2006 | 08:22 PM
SoiledGreen98's Avatar
Lotion and spit!?
Old Aug 25, 2006 | 09:12 PM
ErikJeanna's Avatar
Mine is only on the holder when I'm in the car. I remove it but leave the suction cup on the windshield.
Old Aug 26, 2006 | 05:55 AM
Originally Posted by SoiledGreen98
Lotion and spit!?
Sick B stards
Old Aug 27, 2006 | 11:22 PM
SuaveGato's Avatar
It rubs the lotion on it's skin or else it gets the hose again!
primordialbeast117
Dec 19, 2015 12:23 PM
Badlander
Oct 10, 2015 08:05 PM
irv
Sep 29, 2015 01:04 PM
yoterr
Sep 15, 2015 06:26 AM
Fofo
Sep 14, 2015 01:39 AM
