Gauge Range
Old Feb 28, 2007 | 02:47 PM
Bill's Avatar
Gauge Range
For anyone that is running a 22RTE, what kind of boost pressure are you running on average? It's a really minor thing, but I'm looking for how large a range I should look for in a boost gauge.
I've been told that gauges usually work best in the middle of their range, so I'm not sure if I want a 0-30psi gauge or a 0-15psi gauge. I like the 0-15 more just because I can more clearly see changes in pressure.
But considering I don't think I'd be running less than 7psi and don't think I'd be going more than 15psi(ever), but 15 puts it right at the extreme end of the calibration and won't tell me if I have an over boost problem.
Ideally 0-20, but I can't find one.
OR
Both gauges are the same price: $50 from summit
Old Feb 28, 2007 | 02:52 PM
KyleT's Avatar
http://store.summitracing.com/partde...5&autoview=sku
i personally like to see vac too. that way you can see the transition from vac to boost.
Old Feb 28, 2007 | 03:02 PM
Bill's Avatar
I was thinking about that(range I want), but I'm measuring at the TB so won't ever see vacuum(if I do something is very wrong).
I didn't see that one though, thanks.
Old Feb 28, 2007 | 03:13 PM
mastacox's Avatar
I don't think that you get over 6-7psi of boost, so the 0-15psi should be fine. The 0-30 psi gauge is definitely overkill.
Old Mar 1, 2007 | 11:08 AM
Bill's Avatar
I'm not running the stock turbo...or stock guts.
Old Mar 1, 2007 | 11:44 AM
DudeBud's Avatar
if you are looking for a 0-20 then get the 30psi one, or what about an auto meter gauge
Old Mar 1, 2007 | 11:51 AM
rdlsz24's Avatar
http://search.ebay.com/search/search...psi&category0=
Rob
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
