Braking Problem
Old Nov 7, 2006 | 07:38 PM
CJM's Avatar
CJM
Braking Problem
I dont know if its me or the T100, but my camry did the same thing and it had 4 wheel disc vs front disc/rear drum. FYI: 96 T100 4x4 SR5, 31" tires. Now I do have antilock brakes as far as I can tell b/c the little abs light comeson when I start the truck and when I press downhard (regardless of the problem) they pulsate.
While driving if I am on a regular road (which is graded to let the water run off with the high spot in the middle and either side being lower) if I push down on my brakes with decent force my wheel turns to my left, I just had my brakes and rotors done with brembo blanks and hawk light truck/suv pads (according to tire rack they rate very high). I had the whole passenger caliper replaced 2x already b/c the first one froze up.
I sometimes have to fight the wheel abit to get it to go straight. It feels as if the whole truck wants to turn left a bit and its very annoying. My 93 camry v6 did this same exact thing no matter what I ever did-so either its my driving or a common yota problem.
Old Nov 7, 2006 | 07:43 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
and this doesn't happen on flat roads? what about on hills?
Old Nov 7, 2006 | 07:44 PM
CJM's Avatar
CJM
Flat roads, on hills I didnt notice it to much-its very flat here so I cant say for sure. On flat/semi flat roads its very pronounced if I am going 40 and apply moderate pressure.
Maybe I am nuts and its just the road but wouldnt it make more sense to turn to the grade-that being the right of the road if I am on that side?
Old Nov 7, 2006 | 09:02 PM
CJM's Avatar
CJM
ÅÅÅÅING A! I know what it is now, and I am gonna kill my mechanic! The replacement caliper froze up and I couldnt get back to him so I waited a bit, it due some small gouges into the rotor maybe 1/16" deep b/c the pad was locked in.
I took it back and I told him to turn the rotor and put a new caliper on, looks like he forgot to turn it! Damn!!!
Old Nov 9, 2006 | 04:40 PM
CJM's Avatar
CJM
Ok if it isnt the rotor causing it (will find out tommorow) anyone have any idea what else if could be-just incase?
Like I said, if I brake hard the entire frontend wants to steer tot he left and I need to fight it a bit to get it straight. It tracks fine so its not the alignment.
Old Nov 10, 2006 | 06:52 PM
CJM's Avatar
CJM
Ok rotor did need to be cut as I suspected, but it still pulls to the left when braking hard-maybe the alignment? My mechanic sat with it for 3 hours and is stumped right now, he checked every possible thing but that. I think I am gonna go make an appt for an aligment tommorow.
Old Nov 10, 2006 | 08:02 PM
91TPU's Avatar
sounds like an alignment type of issue, i have the same thing and my alignment is way out. take it to wherever you take it and get he alignment done, it will make a world on diffence
Old Nov 10, 2006 | 08:27 PM
CJM's Avatar
CJM
Thanks for the advice, there is an sts down the road that does good work, gonna give'em a call.
Old Nov 10, 2006 | 09:40 PM
91TPU's Avatar
lucky day for you, the sts by where i live does horrible work, my buddy had his civic in for just two wheels mounted balanced and a 4 wheel alignment, the guy cranked the lugs on so tight with the impact gun that he bent the wheels and the rotors, and it took me a breaker bar and pipe and my buddy pushing on me to get em off...btw where in jerz are ya? im up by hackettstown but i used to live in bloomfield, vernon, basically anywhere central and above.
Old Nov 10, 2006 | 10:38 PM
CJM's Avatar
CJM
Freehold, used to live in ringwood/wanaque area.
Old Nov 11, 2006 | 09:31 AM
CJM's Avatar
CJM
For those intertested, yes it was the alignment as I had figured. Truck now tracks fine and stops fine.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
