Best way to check exhast manifold/train leak?
Old Nov 27, 2006 | 07:32 AM
SwampThing's Avatar
Pretty sure I have an exhast leak either somewhere near the beginning of the exhast train or the exhast manifold. Usually I'm pretty good bout honning in right on em, but this one's a slippery little wraskle... So whats a good way to find out where it's leakin from, short of buyin one of those expensive harmonics detectors lol...
Kinda hopin that its the manifold and not my still fresh off my bud's new mandrel pipes, cause then I'll have an excuse to splurge for some headers
Old Nov 27, 2006 | 07:39 AM
bwhyit's Avatar
Stuff a rag in the tailpipe. It will increase the exhaust pressure and make the leak louder.
Old Nov 27, 2006 | 07:55 AM
all_terrain17's Avatar
Just spray soapy water all over the exhaust till ya see bubbles.
Old Nov 27, 2006 | 07:59 AM
bwhyit's Avatar
Water and HOT exhaust probably aren't the best combo. Leak may be hard to see with all the steam.
Old Nov 27, 2006 | 08:01 AM
^ Good point. Start cold?
Old Nov 27, 2006 | 10:02 AM
SwampThing's Avatar
Urg... Rag in the tailpipe didn't help too much, and hot water and soap couldnt penetrate my awesome layer of impenetrable caked on and baked into basically a brick coating around my exhast pipe and manifold lmao... Off to the car wash I guess
Old Nov 27, 2006 | 10:33 AM
Elton's Avatar
if you have the stock manifold they tend to leak or lose a few bolts my 22re did that all the time i got tired of it so i bought a Lce header
Old Nov 27, 2006 | 11:37 AM
surf4runner's Avatar
my muffler shop had to reweld a spot they missed. w/the acetylene torch on and car running, the annoying leak was easy to locate and fix. HTH.
Old Nov 27, 2006 | 12:23 PM
Keep caking mud on, that will seal the leak! j/k
Old Nov 27, 2006 | 01:03 PM
MMA_Alex's Avatar
I've got a crack in mine, and im figuring out what to buy right now.
Not sure of any tips on finding the leak though.
Old Nov 27, 2006 | 01:12 PM
SwampThing's Avatar
Lmao... Ok, well, I think I found a substance harder than steel. After soaking that damn manifold and pipe in engine cleaner for 15minutes, then trying to spray it off with the high pressure water, the repeating 2 more times, all it did was define the cakes of mud even more! ARRRG! It's like the mud has become one with the truck.... Hmm, so you say it could be from the bolts bein a little loose? Maybe I'll go try and tighten em up... Anyone know what size they are?
At lease my engine is nice an purdy again. Haven't seen my purple block in a lonnnng time lol.
Old Nov 27, 2006 | 02:18 PM
CyMoN's Avatar
run a little seaform in it as the bottle says then stick a sock in the tail pipe works great to find a leak
Old Nov 27, 2006 | 02:42 PM
MMA_Alex's Avatar
i wanna say they're 14mm? mine were loose, but I have a crack in the manifold too
Old Nov 27, 2006 | 04:38 PM
SwampThing's Avatar
Ah well, looks like I'm missin a bolt. In the picture, see on the top right bracket, where there's usually three? The third to the right is missing. That and one bolt on the left side was loose, so I tightened that. Then on a whim I tested the valve cover nuts, and they weren't even hand tight. Tightening those few nuts on the manifold and on the valve cover seemed to help a little, but I think once I get that other bolt from autozone or somewhere, it'll pretty much eliminate the leak. Anyone have the number for that bolt? Would greatly appriciate it
jasonty
41
Dec 23, 2018 01:00 PM
stock87yota
Jul 31, 2015 10:08 AM
jjrbus
Jul 19, 2015 02:06 PM
nick b
Jul 11, 2015 04:38 AM
Coreyr384
Jul 10, 2015 11:13 AM
