Awesome Weber price
Old Dec 8, 2009 | 09:16 PM
86 TOY's Avatar
Originally Posted by seanmearse
Same on this one. But, I'm removing it. Just got done rebuilding the aisin, its proving to be a pain in the ass, so going back to stock. If anyone wants to buy a near new weber (on the truck for around a week) and a fuel pressure regulator, hose, filter, and a pre-filter 200 bucks plus shipping, the regulator is a mr. gasket .2 to 6 psi regulator, let me know.
Got any more feedback? I've considered a Weber to replace my rebuilt Aisin. What was the problem?
Old Dec 8, 2009 | 09:18 PM
seanmearse's Avatar
Just dont have the time to deal with it. I need the truck to run as good as possible as I have a drive to big bear, and snow/wet wheeling planned for the holiday. So yeah, its just not pheasable right now. Ill sell it you.
Old Dec 9, 2009 | 01:34 PM
seanmearse's Avatar
Got the Aisin rebuilt last night, put it on today, let me tell you, I love it. I preset the idle mixture at what blue bass design said, needed no adjustment, idles at 900 rpm's with no fluctuation or misfire. Totally wicked. Jonny is putting the weber on his 83 right now. Hopefully it brings it back to life.
Old Dec 28, 2009 | 02:24 PM
cgeorge's Avatar
whatever happened with the weber on the 83? Did it workout for him?
Old Jan 6, 2010 | 05:10 PM
  #25
tumolt's Avatar
Aisan carb '80 Toyota motorhome
I disconnected and threw away my aftermarket cruise control. I need a schematic for the vacuum hoses, since one hose needs to be connected on the bottom of the adjustment side of the carb. (red dot on tube) Does this correspond with the red dot on the top front of the carb? I also need to adjust the float again. At cold start it runs fast and when warmed up it will not idle correctly. I tried adjusting the idle and air mixture, even turned the air mixture all the way down. It did not stop running. I believe there maybe a leak. Your suggestions and help would be appreciated. This is before I think about a Redline Weber carb kit. Thanks, Matt
Old Jan 6, 2010 | 05:19 PM
  #26
tumolt's Avatar
The motorhome is stock Toyota pickup with a 20r and 4 speed with only 17,200 mile. I re-did everything inside and outside. I call it my little beach house on wheels. I live in Ft. Lauderdale, Florida. I hope to post picture of this beast. I upgraded the rear to a fll floating differential out of a 1989 Toyota Uhaul truck. The Uhaul box was made into a trailer. It has a pull up door, fiberglass reinforced shell, and aluminum floor. The axle is a 3500 lb. Dexter with electric brakes and dually rims, the single rim with two tires that came on the Huntsman motorhome. If you type in Huntsman motorhome you'll understand why I did the rear mod to the motorhome. Yep. The 20r and 4 speed tows just fine. I may opt to put in a 5 speed out of another truck later. The inside of the motorhome is customized. I hope to acquire more knowledge and a better understanding of how members relate to one another and to acquire more friends along the way. Thanks, Matt
user 82300
Jan 19, 2016 02:01 PM
clok
Nov 19, 2015 01:09 PM
pickle6415
Oct 19, 2015 08:08 AM
ctheiss
Sep 14, 2015 12:18 PM
