Is the ARB locker switchable?
Old Nov 10, 2007 | 07:32 AM
CobraLD's Avatar
Not sure if this is the right place to ask this, but I have stock 4.10s on my truck right now running 31s, and I was planning on buying the ARB air locker for the front and rear axles. My question is, later, if I were to decide to upgrade to a lower gear ratio (5.29 etc) would I be able to re-use the lockers. Thanks
Old Nov 10, 2007 | 07:33 AM
4Crawler's Avatar
Yes, you can swap gears on the ARB carrier.
Old Nov 10, 2007 | 07:35 AM
ninjarunner's Avatar
Yes it is completely possible. the ARB has nothing to do with the gear ratio on your rig. Go for it, that way your locked now, and later get the gears you need. although If you can spend a little moer now and do both gear and ARB it will save you money as you need to take the gears out anyway to put the ARB in. so its up to you if you want to save some cash in the long run on labor.
Old Nov 10, 2007 | 07:43 AM
waskillywabbit's Avatar
Yep, but you would be paying labor twice for 2 things that can be done at the same time.
Or get fully built 3rds from us and drop them in.
Old Nov 10, 2007 | 08:15 AM
CobraLD's Avatar
waskilly, your guys' fully built 3rds seem like a pretty good deal, but I just bought these 31s brand new and I would like to get a set of locker's in right away, but If I were to get different ratio (5.29) and still keep these 31s (would not be in my budget to buy the bigger tires or the lifts for the bigger tires) how would the truck drive with the 5.29s running the 31s. I assume that 3k rpms in 1st would be what....35-40kph???. Also I am assuming that the prices on the site are just for a single axle??
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
