5vzfe specs
Old Jun 3, 2007 | 08:30 PM
the_gunslinger's Avatar
5vzfe specs
the 3.4L V6 is an alright engine. it runs forever, make a respectable amount of power, and isn't too harsh on gas milage. but it screams mediocracy.
(if there's already a thread on this point me there)
3378cc DOHC 24V 9.6:1 V6
190hp@ 4800 rpm
220lb.ft.@3600 rpm
93.5mm bore/82mm stroke
that's about all i can find. i'm looking for cam specs, head flow info, injector sizes, etc...
any help would be appriciated, as i'm looking for some optimal mods for a street rig. so far, it seems to need a stroker crank, maybe coated 10:1 pistons, and either shorter intake runners or a larger plenum...
it's off topic, but i came across these, and think ya'll might enjoy
Old Jun 3, 2007 | 08:45 PM
tc's Avatar
tc
Ummmm - there's a gazillion threads about supercharging the 3.4L and fuel mods to max it out... or you could call URD and talk to them...
Old Jun 3, 2007 | 08:50 PM
i don't want to supercharge it...i'm just gonna give it a little more personality. i bet i can get the cam specs and maybe the head flow from URD, thanks
it sounds like a hoover vacuum, a little compression and tinkering with the EVC point could fix it up a bit...
Old Jun 7, 2007 | 08:05 AM
EnolaGaia's Avatar
Have you checked any of the online Factory Service Manual documentation? You should be able to find a lot of tech spec's / data there ....
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Oct 4, 2015 11:30 AM
dbollier123
Sep 29, 2015 05:23 PM
