Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
1984 4x4 won't shift to 4wd ????
Old Mar 27, 2015 | 08:12 AM
optimumpear420's Avatar
I have a pickup that won't shift out of 2wd any suggestions would be very helpful
Old Mar 27, 2015 | 09:38 AM
millball's Avatar
Is the truck new to you?
If not, have you ever been able to shift the transfer case in the past??
Removal of the shifter and examination of the shifting rails and shifter bottom button might be enlightning.
Old Mar 27, 2015 | 09:45 AM
Yes its new to me but IT has been in the family with one owner and he said when he parked it that it worked but I have never shifted it someone said there is a spring that might not be working right but I don't know where this spring is even located ????
Old Mar 27, 2015 | 11:58 AM
millball's Avatar
The factory Service manual knows all.
Old Mar 27, 2015 | 12:12 PM
Unfortunately I don't have that
Old Mar 27, 2015 | 12:44 PM
millball's Avatar
Here is a link to the 1985 FSM.
Your truck should be similar. --
http://www.precision4wheeldrive.com/1985FSM.pdf
Takes a while to load.
Might look here as well--
http://web.archive.org/web/201209012...fsm/index.html
Old Mar 28, 2015 | 03:58 AM
Thank you for that link , I didn't even think of that, people like you are the reason I got this app thanks millball
Old Mar 28, 2015 | 01:58 PM
shadowbirdie's Avatar
The FSM is great,
The FSM is great, but I don't think it recognizes aftermarket issues like
a 3 inch BL which is affecting my TC shifting, other resources cover the slack though...
J
Old Apr 26, 2017 | 10:10 PM
kjjk56's Avatar
Does this Pickup have the AISIN 4x4 Locking Hub Dial? Or is it not shifting in the transfer case? The Locking Hub Dial has a spring that goes in and out depending on freewheel of locked wheels to the axel.. check the front tires
mskalmus
May 28, 2017 07:51 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
hangtown88toy
Jul 10, 2015 02:33 PM
crashburnoveride
Jul 10, 2015 06:39 AM
