Sponsored by: CARiD
Which Zuk mod???
Old Mar 30, 2011 | 11:05 PM
cman1's Avatar
The brownish,red stuff is compliments of wisconsin!!! it actually looks alot worse than it is,the frame itself is alot more solid than it seems. By all means use the pics ....thats how i learned,the link looks good to me. again,thanx for the input and info.!!!!
Old Mar 30, 2011 | 11:10 PM
nlinn's Avatar
hey cman,
what size tires are you running? are they 31's?
your runner looks great by the way
Old Mar 30, 2011 | 11:41 PM
ZUK's Avatar
ZUK
Link ready...now to post it to my webpage....top row with the other coil links
http://gearinstalls.com/cman1.htm
Got any cool looking snow pics, I'll add them in also
Again cnam1....nice job you did there on making the install clean and simple.
Old Mar 30, 2011 | 11:54 PM
cman1's Avatar
theyre 32x10.5x15s...i dont want to go bigger wo/gears.
Old Mar 31, 2011 | 04:50 AM
  #25
tofattofish's Avatar
Sweet rig man! Nice Mod. I'm thinking of do the ZUK mod as well, but can't decide on
12" or 14" springs. Was your suspention stock before the mod?
Old Mar 31, 2011 | 07:20 AM
  #26
ZUK's Avatar
ZUK
2 measurements with the tape measure to help you make that decision.....
1----with the truck/runner in normal stance on flat ground, measure the spot where the coil would be located at.
2----flex the rear suspension is a cross ditch or similar to get the wheel to drop as far as it ever hopes to drop and take a new measurement where the coil would be located. If the distance is much over 14 inches then a spacer would need to be fabbed on either end of the coil to keep it tight when off-roading or flexing. Nobody that has a stockish Runner has ever ran into that issue so far....not sure about pick-ups as they have a higher arch in the back of the frame.
Old Mar 31, 2011 | 09:04 AM
  #27
cman1's Avatar
Mine was completely stock, i probably could have gone with a 12" 100# spring, but i haul a trailer for firewood,boat etc.also id like to add,i live in wisconsin,so the most i get into is trails,mud, no real rock climbing,so,i personally think that for a close to stock ride and a slight rake,with really good clearance for 32x11.5x15 BFG A/Ts, the 14s 125# and a slight t-bar crank (2 full turns) is the way to go.also,its inexpensive enough that if you want to try the 12" 100# springs and you dont care for em',you can swap em out.im sure someone on here will give you a few bucks for em'. win win.
Old Mar 31, 2011 | 10:05 AM
  #28
ZUK- thanks for the advice I'm gonna get that done this weekend..weather permitting.
cman- good point about it being cheap enough to switch to the 14" spring if the 12s don't cut it. did the 32s rub at all with stock suspension? thanks
I'll post up some pics after I decide and complete the mod
Old Mar 31, 2011 | 10:14 AM
  #29
cman1's Avatar
YES... but not now.
another little tip i just remembered,my bottle jack wasnt quite high enough,so i used the upper (metal) bump stop i had cut off as a spacer on top of the leaf spring to set the jack on...if that makes sense. Have fun!
Old Mar 31, 2011 | 12:20 PM
  #30
Originally Posted by cman1
YES... but not now.
I can see it in my mind already
Old May 26, 2011 | 10:26 PM
  #31
ZUK's Avatar
ZUK
hey cman1- I saw a thread where you sold the awesome Runner and got this pick-up.....is the new owner aware of the coil?
So, this pick-up looks like it has a 4" front IFS lift....and does that mean it has some nasty 3~4" blocks in the back? Sweet ride by the way.
Old Jan 23, 2012 | 11:38 PM
  #32
cman1's Avatar
well,its got a 2" BL and HAD aals in the back,removed aals and uncranked Tbs and undid a ton of other crap from the PO. heres a new pic with winter tires,body line rhino-lined and a new(old) fiberglass lid i picked up for $50.00.
Old Feb 10, 2012 | 04:53 PM
  #33
ZUK's Avatar
ZUK
cool ....can't see pic yet.
Old Mar 30, 2013 | 11:22 AM
  #34
-City Slicker's Avatar
I'm gunna go with the 12" to obtain stock height.
but
I have an extra cab pickup with a shell and a carpet kit bed setup..
with the extra weight I was thinking of using the 175 lbs. springs instead of the 150's
any thoughts...?
I'll also need new bump stops? should I get new poly rubbers as well..?
Old Mar 30, 2013 | 11:40 AM
  #35
cman1's Avatar
I personally wouldn't go any heavier than a 125#,it gets too stiff.but,thats the beauty of this mod, if you don't like the ride, swap em out for softer ones!!! ive got 100# on my 80 longbed and wouldn't go any heavier on that.
Old Mar 23, 2015 | 02:58 PM
  #36
icentropy's Avatar
i went to do this on my new project 4runner but noticed it doesn't have any lower bump stops. I looked around and can find any part for this truck (it's an 85) does anyone have a PN for the lower bump stops? or a good place to get them?
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
