Sponsored by: CARiD
Won't start!
Old Apr 16, 2011 | 05:42 PM
bio6040's Avatar
Won't start!
I've got an 86 runner 22re and the problem I'm having is it won't start! When I turn the key to the start position all I get is the Charge red light on the dash nothing else. The radio works and the door chime, but won't click or turn over, nothing. Does anyone know where to start? It was running earlier today before I parked it. Any help would be great, Thanks!!
Old Apr 16, 2011 | 06:02 PM
crash121's Avatar
start with battery connections and fuses.
Old Apr 16, 2011 | 06:08 PM
bio6040's Avatar
found it neg. battery cable very loose and cracked. Clamped it down tight and it started right up. Hope that was the extent of the problem. Thanks for the help!!
Old Apr 16, 2011 | 07:08 PM
guitarplayer360's Avatar
i remember once I went out to my runner and it wouldnt start. It was wierd it never once had a problem, and hasnt since I jumped it that night. I cleaned the terminals and tightened the clamps. Seemed to do the trick
Old Apr 23, 2011 | 12:51 PM
bio6040's Avatar
Well the problem is back! This morning went to drive the runner and it started up and drive around town fine. Then the charge light and parking brake light came on and it would not start again. Same symptoms as before! I have since replaced the neg. battery terminal clamp and connections, checked the fuses in the driver's side kick panel, and tried to jump start it. Nothing! Any help would be great. Thanks!!!
Old Apr 23, 2011 | 01:09 PM
wyoming9's Avatar
Red face
Ok for some reason you still have a bad ground.
What is the voltage at your battery??
Old Apr 23, 2011 | 01:13 PM
bio6040's Avatar
12.25 currently. It seems when I remove and then reinstall the fuses in the black box behind the battery the truck starts again. The fuses look to be ok. Is there connections under the box that could be tighted?
Old Apr 23, 2011 | 01:15 PM
bio6040's Avatar
Running 14.43.
Old Apr 23, 2011 | 01:31 PM
bio6040's Avatar
I tighted up the wires under the 80A fuse in the black fuse box behind the battery (one of the screws was on its last thread). That might have been the problem? The battery is holding at 14.52 running right now. Thanks for the help again!! I'll keep posting if that doesn't work.
Old Apr 23, 2011 | 01:57 PM
crash121's Avatar
ive had a problem similar to this. check to make sure your positive connections to the battery are secure. if you have a good connection to all wires other than the one going to the starter itself then everything will work except for the starter, and this includes the starter relay. so you turn the key and it clicks but nothing happens. something to look into
Old Apr 23, 2011 | 05:36 PM
bio6040's Avatar
All the starter wires are tight. Thanks for the replay!
Old Apr 27, 2011 | 10:37 PM
viker350's Avatar
really cheack the fuse in the inside and under the hood
Old May 4, 2011 | 09:36 AM
eastoncatcher3's Avatar
Im having the same problem. all my lights will come on. i turn the key and it clicks. the starter is engaging but not turning. Its a brand new starter just bought it yesterday. any help with that?
Old May 4, 2011 | 09:56 AM
ChickenFriedMX's Avatar
Guys I just went through the same problems, I wired a push button like this. Power from battery with a 30amp fusible link to push button, from push button to starter ignition wire(the small one) I had a ghost in that wire, and now I can start it with my key and my ignition, has not given me any problems since. I trouble shot every component in the start system and that wire had a break in somewhere, all in all it was a 20 dollar fix, As long as your starter is still good of course.
sandyota
Feb 4, 2021 11:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
