Sponsored by: CARiD
where to get an extended brake hose or specs
Old Apr 12, 2011 | 02:01 PM
gubni's Avatar
My 88 4runner has the rancho lift kit with downy slip yoke axles. One side has a stainless extended brake hose. The other side is a stock rubber hose. I want to get another stainless hose. Any suggestions on where to get one?
Old Apr 12, 2011 | 02:13 PM
crash121's Avatar
I'm not sure if this is every location or not but the napa here does custom brake lines. Call your local one and ask
Old Apr 12, 2011 | 03:53 PM
gubni's Avatar
Nope, mine doesn't. I can't get any of the local suppliers to make them either.
Old Apr 13, 2011 | 08:28 AM
Outsane's Avatar
from Pirate4x4 FAQ
http://www.pirate4x4.com/forum/showthread.php?t=775780
Brake Lines
Toyota Fittings are 10mm x 1.00 thread with an inverted flare.
ProComp #7210 are Longer than stock Stainless Steel brake lines. (set of three)
One piece 23" long replacement brake line for the front is Napa #38688
[EDIT: This turns out to be a front line from a 90-96 Nissan 300ZX if you wanna get one from somewhere else.]
The flexible rear brake line (goes from the hardline to the rear axle) is commonly used for extending the front and rear brakes lines since it has one male end and one female end. So when these lines are swapped inline with the stock lines, and you will have plenty of room for extra lift and flexy suspensions. The Napa #38256 is the stock length (19" long) rear flexible brake hose. Napa #36881 is 11" long if you need one a bit shorter.
Good source for custom SS Brakelines (recommended by steveh)
http://www.pirate4x4.com/forum/showthread.php?t=449419
young buck
18
Aug 27, 2018 02:40 PM
94 Newbie
Aug 6, 2015 10:33 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
CanRunner
Jul 20, 2015 01:29 PM
jjrbus
Jul 19, 2015 02:06 PM
