Sponsored by: CARiD
What tranz gear oil???
Old Jan 16, 2009 | 02:29 AM
dub tek's Avatar
Just getting into this 88 4runner i got
Is there a quick how-too on manual transmission fluid replacing??
I need to know WHAT oil to run when its COLD in winter
VS
WHAT oil to run in the summer months
Only asking as the manual that I ordered from the steelership is still NOT here..
22re
5speed manual
I am asking because when the truck is cold it wants move forward from fluid dynamics internal to tranz.. I am assuming that someone has the wrong viscosity in there..and I dont know what the specs fluid is!!!
thansk for all the help yotatech
Tek.
Old Jan 16, 2009 | 02:49 AM
nosfanatic2006's Avatar
You could always call the Toyota service department and ask them?
Old Jan 16, 2009 | 02:52 AM
toyota4x4907's Avatar
Per Chilton manual, fluid recommendations GL-3, GL-4 or GL-5 with viscosity SAE 75W-90 or 80W-90. Use the lighter weight for the winter. Arguably the best for cold weather is synthetic fluids. How cold does it get where you live? IF it doesn't get TOO cold, then don't worry too much about not using synthetics.
Old Jan 16, 2009 | 12:10 PM
dub tek's Avatar
My local dealer is WORTHLESS with the tech/answers/part#'s
Only reason I am asking is it was -15degF today
and the trans seamed to want to drive the truck forward even in neutral..
thanks for the GL + 75-90
Old Jan 16, 2009 | 12:17 PM
4Crawler's Avatar
What my Owner's Manual recommends:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
and what I use:
- http://www.4crawler.com/4x4/index.sh...ntheticGearOil
Old Jan 17, 2009 | 05:26 AM
rtn's Avatar
rtn
Originally Posted by 4Crawler
+1
I recently bought an '04 Taco 5-sp and changed all the fluids. For the transmission I used Redline MT-90. I bought it at Napa (I had to ask for it) but it's also available online.
The key point is to use a GL-4 and not a GL-5, which can be problematic for the transmission's brass/bronze parts.
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
