What can I do to lift the front for cheap
I have an 84 with SA and im raked just a little towards the front. Im just looking for a cheap way to lift the front a few inches. I was thinking of a shackle but I dont want to throw my pinion angle out of wack. Are there any junkyard leaf spring tricks out there i can do for cheap. Thanks
As said by wabbit, it won't mess it up noticeably. if you add 5" shackles, then yes its going to make a big difference. But 1" to 2" shackles will not be a problem.
There is a "cheap" junkyard fix, which is to do a "Rears up front" conversion, or just buy a few leaf packs from the yard and build your own.
Longer shackles may give some lift up front:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Easy enough to correct the pinion/caster angle:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
