Sponsored by: CARiD
What can I do to lift the front for cheap
Old Nov 16, 2009 | 06:20 PM
flatyota's Avatar
I have an 84 with SA and im raked just a little towards the front. Im just looking for a cheap way to lift the front a few inches. I was thinking of a shackle but I dont want to throw my pinion angle out of wack. Are there any junkyard leaf spring tricks out there i can do for cheap. Thanks
Old Nov 16, 2009 | 06:22 PM
waskillywabbit's Avatar
Longer rear shackle is probably the easiest and won't mess up your pinion anything noticeable.
Old Nov 16, 2009 | 06:42 PM
elblako91's Avatar
Doesn't a longer rear shackle lift the rear??
Old Nov 16, 2009 | 07:08 PM
DeathCougar's Avatar
As said by wabbit, it won't mess it up noticeably. if you add 5" shackles, then yes its going to make a big difference. But 1" to 2" shackles will not be a problem.
There is a "cheap" junkyard fix, which is to do a "Rears up front" conversion, or just buy a few leaf packs from the yard and build your own.
4Crawler's Avatar
Longer shackles may give some lift up front:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Easy enough to correct the pinion/caster angle:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
Old Nov 17, 2009 | 11:20 AM
mudinyeri's Avatar
Rears up front (RUF) is about as cheap as you can go to my knowledge. If you're anywhere near Omaha, NE I have a couple sets.
Old Nov 17, 2009 | 07:41 PM
desertcamper67's Avatar
Find a used 2-3 inch lift spring pack. Junk yard or another Yota owner.
Old Nov 26, 2009 | 05:02 PM
84toyota4x4extcab's Avatar
just add a leaf and get your springs crowned
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
