Sponsored by: CARiD
Weird clunking after SAS
Old Oct 5, 2009 | 04:19 PM
SAS'd 86Runner's Avatar
My 86 SAS'd 4runner has started this weird clunking sound as the front wheels rotate, it sounds like it might be just the right side.
It gets a little worse when i turn either direction and goes away when i brake.
I'm about to start looking for the problem, I was just wondering if anyone has any info on what i could look for before i start tearing everything apart.
Thanks guys.
Old Oct 5, 2009 | 04:35 PM
4banginRunner's Avatar
loose caliper?
Old Oct 5, 2009 | 04:42 PM
camo31_10.50's Avatar
could it be a birf???
busted half shaft??
bad bearings??
Old Oct 5, 2009 | 04:55 PM
whokrz's Avatar
clunking normally means something is worn or loose.
I would start by jacking the truck up and seeing if it clucks with out weight on the tires.
If it is not obvious what the problem is I would open up the axle and visually inspect all of the parts then torque every thing to spec. I would also inspect/torque steering, brakes and suspension to spec.
In my sig is a link to FSMs if you need torque specs.
Old Oct 5, 2009 | 06:48 PM
I shoulda just went and looked at it before i posted cause it was simple stuff,
The passenger side wheel spacer was loose and that was causing the most noise, guess i should checked the torque on those after i put some miles on her.
The drivers side was the the bearing nut was loose, i guess i didn't get it tight when i installed my 3rds last time.
Rookie mistakes, but thanks for all the help guys, what a great board!
Old Oct 5, 2009 | 07:05 PM
yea dude you needa stay on top of things..lol
that spacer being loose coulda let ur feakin wheel come flyin off..hahaha
Old Oct 5, 2009 | 07:09 PM
Yeah i know, I got really lucky it didnt come off this morning when i was driving on the freeway at 80 mph.
Old Oct 5, 2009 | 07:14 PM
myyota's Avatar
Lets see some pictures of your 4Runner.
Old Oct 5, 2009 | 07:31 PM
OK
Old Oct 5, 2009 | 07:32 PM
niiice...lets see that rear stufffffinnnnn
Old Oct 5, 2009 | 07:54 PM
a couple more
Old Oct 5, 2009 | 08:04 PM
TOYOTA 1's Avatar
put loctite on there if you havent already.
nice runner by by the way
Old Oct 5, 2009 | 08:08 PM
myyota's Avatar
Looks good, are you going to fix the rust on the back fenders ?.
Old Oct 6, 2009 | 08:59 PM
Thanks, I havent decided whether i'm gonna fix the rust or just cut the fenders out for bigger tires? We'll see.
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Odin
Sep 26, 2015 06:56 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
