Sponsored by: CARiD
v-8 swap
Old Jan 30, 2011 | 09:16 PM
nhclocal's Avatar
v-8 swap
I'm planning a v-8 swap in my 1984 pickup 4x4. I like the buick 215 all aluminun because it only weighs 320 lbs. same as the 22re I think. Havn't called advance adapters yet, but they don't list it on their website. Anybody done this one?
Old Jan 30, 2011 | 10:09 PM
2DoorRunner's Avatar
Been done. But if i remember correctly its not the best choice of a motor to use. I beleive it has some fitment issues, has a bad imbalance problem, and you better be good at fabrication, because i dont know of anyone who makes any adapter parts.
If i was doing a v8 i would probably use a Ford 302. The distributor is on the front and gives better firewall clearance.
But a chevy 350 is a good choice too.
Also look into a Chevy 4.3 or Toyota 3.4 for a v6 swap.
Old Jan 31, 2011 | 04:45 AM
waskillywabbit's Avatar
You didn't find a lot of information on this if you searched for a reason.
:wabbit2:
Old Jan 31, 2011 | 04:22 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
uhh... wasn't that the engine Land/Range Rovers used?
Something about slipping a liner?
Old Jan 31, 2011 | 04:25 PM
Though I am a Chevy guy, x2 on the Fords because they have the dist in the front...
And, I can't remember it now but I watched Hot Rod TV, or some show on SPEED where they used a modern Ford V6 that had V8 like power, and it was easier than pie to convert...
In the show they only changed ONE thing to make it stand alone.
For the life of me I can't recall what it was...
Old Jan 31, 2011 | 07:13 PM
nhclocal's Avatar
Buick v-8 swap
Really appreciate the input. Second choice IS a Ford 302. I was just concerned about the additional weight. And is the stock 5-speed up for the challenge?
Old Jan 31, 2011 | 07:16 PM
You can get some different springs that will hold the extra weight easily.
And for daily driving, most people say yes.
Wheeling, i would never risk it, unless it was a r151f turbo trans.
But many people run v8s, with the stock v8 trans, adapted to a toyota gear driven t-case, and say it works fine.
I have no experience with it though.
Old Jan 31, 2011 | 09:09 PM
jpsstewart3's Avatar
I truthfully feel the 1UZFE Lexus v8 is the best v8 you can put in a yota. This way u can keep everything toyota without having to get change the tranny or t-case. Plus the power specs are amazing without being too much for the drivetrain parts to handle. (sometime in the near future i will be installing one in yota)
Look into the engine swap section, you'll find plenty to get you started.
Old Feb 17, 2011 | 05:35 PM
atvsorus's Avatar
v8
about how much for a lexus engine
Old Feb 17, 2011 | 05:37 PM
Not sure on a price. But i know the 1uz swap is much more work to get it to fit right. Its becoming more common though. So im sure you could figure it out if thats the path you choose.
Old Feb 17, 2011 | 05:59 PM
vital22re's Avatar
totally a bro
Please stop, and take a couple hours to look through the motor swap section. A lot of what you're asking can be answered by looking through that.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
