Sponsored by: CARiD
TPS Screw size
Old Feb 13, 2011 | 01:05 PM
dieseleater101's Avatar
TPS Screw size
Hi, i recently picked up an 89 toyota with a 22RE. It had idle problems and start up problems. I found the problem...both screws for the TPS are missing. No part stores around here can look up the size of screw i need. If any one on here can either pull on of theirs out and measure it or knows the correct size, it would be greatly appreciated. Thank you
Old Feb 13, 2011 | 01:17 PM
xxxtreme22r's Avatar
pick em up from a dealer: it's one of these two or 1 of each. Diagram isn't clear:
90079-11003 or 90079-11004
SCREW, W/WASHER 90079-11003 1 $0.71
SCREW, W/WASHER 90079-11004 1 $0.62
Old Feb 13, 2011 | 01:50 PM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/CheapTri...llenHeadScrews
Old Feb 13, 2011 | 03:42 PM
thanks for the photo and link. helped out a lot. now time for the fun part...setting it
Old Feb 17, 2011 | 10:28 PM
kountry's Avatar
x2 on the 4crawler link, thats where i got the measurement for mine 4mm x 16mm
Old Jun 9, 2024 | 01:43 PM
Jmiller12393's Avatar
Attachment 200098
Does anybody know what the hose 22210D is or where I can buy one
Old Jun 12, 2024 | 08:35 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Does anybody know what the hose 22210D is or where I can buy one?
What year?
it circulates water/coolant through the throttle body and idle air control valve to adjust engine rpm’s depending on engine temp
thefishguy77
May 7, 2014 12:42 PM
412eRunner
Jan 6, 2014 10:22 PM
Neil McCon
Jun 15, 2013 05:12 PM
MIKEMOKAS
Jun 27, 2007 12:40 PM
