Sponsored by: CARiD
Should this worry me?
Old Apr 10, 2011 | 04:44 PM
guitarplayer360's Avatar
I'm not too worried, but still want to make sure. Does this look like anything I should be concerned about?
Rear diff:
I dont remember seeing a differential ever looking this wet
Old Apr 10, 2011 | 04:57 PM
Swimmerboy2112's Avatar
Mine has a dark spot like that too, no worries.
Old Apr 10, 2011 | 05:12 PM
wifes4now's Avatar
your good
id clean it up and see if it comes back
but its not enough to worry at all
Old Apr 10, 2011 | 05:18 PM
didnt think so...just wanted to run it by a few people. Thanks guys.
Old Apr 10, 2011 | 05:22 PM
jason191918's Avatar
put a new gasket on it when you change the fluid next.
Old Apr 10, 2011 | 05:25 PM
TylerH's Avatar
I would atleast check your fluid. I ignored mine and it fried a pinion bearing. But mine was leaking from the bottom.
Old Apr 10, 2011 | 06:35 PM
Diablo22RE's Avatar
Mine has the same thing, except it is a bit more, and at the very bottom. But so far it's still running good.
Old Apr 12, 2011 | 12:15 PM
maistroyoda's Avatar
That's good advice right there. Change it if it hasn't been done recently, put a new gasket or washer and you should be good to go.
Old Apr 19, 2011 | 06:31 PM
Ron Helmuth's Avatar
Once you learn it's not really leaking then consider using synthetic gear oil in there.
Get other opinions as well, not everyone loves synthetics, but it's another peace of mind issue with me.
Also would not be a bad time to check the breather plug at top of the diff.-they are cheap to replace so just consider doing it and/or doing the "extended breather diff mod" while at it.
Old Apr 19, 2011 | 07:45 PM
Tofer's Avatar
Sponsor
thats a HUGE problem! you should probably just sell me your truck.. with that issue you'll be lucky to get $100 for it.. i'll give you $150 cuz i'm such a nice guy
like everyone else said, no worries
Old Apr 19, 2011 | 07:51 PM
worshipmentor's Avatar
"my toyota truck doesnt leak.........it marks its territory"
Steven.m.paulk
Jun 7, 2020 10:45 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
oldblue
Sep 28, 2015 04:07 PM
