Sponsored by: CARiD
Residue on radiator cap?
Old Nov 8, 2013 | 10:14 AM
Abraham Contreras's Avatar
I got this oil like looking residue on my radiator cap is this normal or a bad sign? It's an 83 sr5 pickup 4x4
Old Nov 8, 2013 | 10:32 AM
Discombobulated's Avatar
Have you recently flushed the system? Doesn't look like anything I personally would worry about but you can always drain a little in a cup and see what it looks like.
Does the coolant look normal when you take the cap off?
Old Nov 8, 2013 | 10:41 AM
Originally Posted by Discombobulated
Have you recently flushed the system? Doesn't look like anything I personally would worry about but you can always drain a little in a cup and see what it looks like. Does the coolant look normal when you take the cap off?
Yes when I rebuilt my motor recently I took the radiator to get cleaned out. and the coolant does look normal to me
Old Nov 8, 2013 | 10:43 AM
Yea, wouldn't worry about it too much might be some residual from the rebuild, if something was failing it would be noticeable looking at the coolant.
Old Nov 8, 2013 | 10:58 AM
wyoming9's Avatar
Red face
Just a little oil in the engine most likely used as assembly lube or to keep things from rusting .
Now if it gets much worse just keep an eye on things
Old Nov 8, 2013 | 11:43 AM
Thanks guys I appreciate it
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
zombie_stomp
Aug 30, 2015 10:26 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
TJWilly
Jul 31, 2015 02:05 PM
