Sponsored by: CARiD
Removing brake hose - rusted on, wrench only rounding bolt
Old Apr 23, 2009 | 08:05 AM
wilshire's Avatar
I put new brake calipers on my truck. The old calipers are still hooked up to the brake system. I cannot get the brake hose bolts to budge. They're frozen in with rust pretty badly. All my wrench is doing is rounding the bolts.
I'm thinking about just cutting the hose so I can use a socket or box end wrench to get the bolts off each end, and just installing a new hose.
Does that sound like a reasonable way to go about it?
Old Apr 23, 2009 | 08:13 AM
4Crawler's Avatar
Try a flare wrench first:
Old Apr 23, 2009 | 09:27 AM
Fae_Tal's Avatar
it seems too simple a solution (so I'm willing to hedge I'm going to get schooled...)
careful application of WD-40?
careful as opposed to willy-nilly spritzing of every surface of course, I know the WD can make hoses brittle etc etc... but since you're at the "Eff it I'm cutting off the dumb hose" phase it can't hurt right?
Old Apr 23, 2009 | 09:40 AM
lofreqjeff's Avatar
Vice Grips, lots of penetrating lube and patience worked for me when I was replaciing my brake lines.
Old Apr 23, 2009 | 09:44 AM
Lumpy's Avatar
PB Blaser works wonders!!! Best stuff I have found for rusted/frozen bolts, nuts. Just keep it off plastics.. READ the label.
Old Apr 23, 2009 | 10:19 AM
wilshire's Avatar
I've already tried PB blaster, vice grips, and patience. If a 10mm flare wrench doesn't do it, i'm cutting them off.
Old Apr 23, 2009 | 10:53 AM
VSU_4runnin's Avatar
believe it or not tabasco sauce works great.. put it on and leave over night
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
