Sponsored by: CARiD
Removing 3" BL question
Old Nov 25, 2007 | 07:08 PM
sleaz22xx's Avatar
I am planning to remove a three inch BL from my 94 4Runner that was installed by the PO, i know i will need to remove the spacer in the steering shaft, will i need to address the gas tank filler neck? are there any other hang ups i should look out for when bringin m body down. any input is appreciated
Old Nov 25, 2007 | 07:09 PM
PoleVaulter95's Avatar
if it is an auto then there is a shifter bracket. also keep in mine if those bolts arent threaded the whole way you will wont to get shorter ones
Old Nov 25, 2007 | 07:31 PM
sleaz22xx's Avatar
it is an auto, would the fact that the indicator on the auto trans level reads incorrectley indicate the lack of use of a bracket by the po?
, i will be using completely new hardware
Old Nov 25, 2007 | 09:44 PM
4Crawler's Avatar
As they say, "removal is the reverse of installation":
- http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
Bumper and radiator brackets, possibly shifter brackets, steering extension among other items.
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ11
Old Nov 26, 2007 | 10:09 AM
sleaz22xx's Avatar
Thank you for the links 4crawler
kazuya2416
Apr 5, 2024 02:17 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
icentropy
Jul 14, 2015 10:23 AM
