Sponsored by: CARiD
rear differential - what's the hole for
Old Jun 19, 2010 | 02:54 PM
maroon harpoon's Avatar
We have a 1979 Toyota that had a leaking differential, so today we pulled the rear-end, replaced the gasket (stopped the leak!) and found a quarter-sized hole on the top of the differential with a smaller hole, threaded, that looks like it held something in the hole...our book shows nothing of the kind and I wonder if anyone knows what that hole is for......and would pass the info on to us!
Thanks in advance!
Tim
Old Jun 19, 2010 | 02:58 PM
PismoJoe's Avatar
Differential Breather? Much smaller than quarter sized though, should be on the top of the differential housing
Old Jun 19, 2010 | 02:59 PM
1981 yota's Avatar
any pics
Old Jun 19, 2010 | 03:00 PM
PismoJoe's Avatar
This has an extended diff breather tube attached, but its on the top left of the differential housing for reference if this is the part in question
Old Jun 19, 2010 | 03:02 PM
Lysmachia's Avatar
Google Toyota Diff Breather
https://www.yotatech.com/forums/f115...r-caps-158023/
http://www.google.com/search?sourcei...+diff+breather
And for SURE read this thread... https://www.yotatech.com/forums/f116...eather-113377/
Old Jun 19, 2010 | 03:04 PM
Lysmachia's Avatar
FYI people extend their diff breathers so that when going through water, the hot axle doesn't pull water into the differential and soil the diff oil. So if you drive through water higher than that hole, you need to do a diff breather extension like the pic above (both front and rear)
Old Jun 19, 2010 | 03:18 PM
I didn't get a picture, but it is not the breather...the breather is on the axle housing, this hole is on top of the 3rd member, right in the middle...
I'll see if I can get a pic...
Tim
Old Jun 19, 2010 | 03:24 PM
1981 yota's Avatar
ok i just went out and looked at my axels there are only 3 holes, the breather,the drain plug, and the filler hole
Old Jun 19, 2010 | 03:33 PM
Here is a pic...the arrow is pointing at the cork that I stuck in the hole...the hole is around the cork...
Tim
Old Jun 19, 2010 | 03:36 PM
1981 yota's Avatar
huh idk ive never seen a hole right there
Old Jun 19, 2010 | 04:07 PM
tzonni's Avatar
ABS Sensor, put a freeze plug in and call it a day, or go to pull a part and get a sensor and cut the wires.
Old Jun 19, 2010 | 04:15 PM
1981 yota's Avatar
ABS in a 79
Old Jun 19, 2010 | 04:16 PM
tzonni's Avatar
Originally Posted by 1981 yota
ABS in a 79
ABS in whatever that third is out of.
Old Jun 19, 2010 | 04:18 PM
1981 yota's Avatar
oh good point
Old Jun 19, 2010 | 04:21 PM
myyota's Avatar
I don`t think that is the original third member in that truck, that hole looks like its for an ABS sensor.
Old Jun 19, 2010 | 05:48 PM
cws9685's Avatar
yea plug it and you will be fine
Old Jun 19, 2010 | 07:57 PM
PismoJoe's Avatar
I think he already plugged it in the pic
Old Jun 20, 2010 | 10:34 AM
Thanks for the replies! I thought perhaps it was for an ABS for whatever vehicle it came out of...suspicions confirmed!
Thanks again...
Tim
Old Oct 4, 2010 | 09:35 PM
yotalaz's Avatar
i have the same hole or mount for my diff i was told its for an e-locker so its for abs?. were they lying?
Old Oct 4, 2010 | 09:57 PM
myyota's Avatar
The hole is for the ABS sensor, not an e-locker, so yes they were lying to you, or they had no clue what they were talking about.
