Rear Differential Drain & Fill Plugs
So this past weekend I decided to replace the oil in my front differential, transfer case, and rear differential. On Saturday I sprayed down all the nuts/bolts with PB Blaster and let them soak overnight. I started with the front differential, no problem. Then I moved to the transfer case, again, no probelm. Then I got to the rear differential, and nothing. The drain and fill plugs will not budge! I even had a neighbor help me and the two of us still couldn't get either of them to move
. After about an hour of wrestling with the bolts
, I gave up and just spraying it with more PB Blaster and I figured I would try it again sometime this week because I was worried that I was going to strip the bolt and make the problem even worse. So, does anyone have any tips/tricks that I can use to get the darn bolts off?
I just did this over the weekend and mine were pretty frozen on there too. I just hit it with PB blaster and broke out my 24 inch breaker bar. Had to put quite a bit of force on it but it went...so did my knuckle into the leaf spring.
Man I hate the smell of gear oil. It almost makes me sick.
My breather was also rusted shut, so I ordered two new ones from the dealer. Don't forget about those.
6pt socket and nothing else, 1/2" breaker bar and an impact socket is best. 3/4" if you must. Impact gun is also possible if you have one. Before using impact gun, I suggest you find yourself a new plug first.
Mine was hell to pop as well. I don't think the PO ever checked it.
still can't get my rear diff on the 4runner loose. I've PB blasted it, torqued on it with cheater pipe (6pt socket as well, 1/2" drive), torched it, hit it with a hammer.... it almost looks like it's part of the diff itself, won't budge even with a little chisel action. I'm tempted to get a BFDrillbit out and solve this the power tool way... need to rebuild/regear soon anyway...
better luck to you!
better luck to you!
i'd give it a couple more days soaking in PB blaster and then try a long cheater bar for leverage. might not be a bad time to install some low-profile magnetic drain plugs before you fill it back up.
My rear diff drain plug was kind of rounded when I bought and it is defiantly rounded now. Anyways, I ended up sucking all of the gear oil out with a syringe. Maybe in the Spring when I don't need 4x4 I will take time to remove and replace it. I am thinking a blue flame wrench and an extractor. Some must take the quality of a Toyota pickup so much for granted that they didn't bother to perform routine maintenance or so it seems.
better luck to you!
better luck to you!
Hopefully I can get it off without stripping it, but it was pretty unwilling to move so I will have to see what happens this weekend...
better luck to you!
better luck to you!
I got mine from Inchworm, but you can get them from pretty much any vendor who sells transmission, transfercase or differential parts: Marlin, Inchworm Gear, etc. They're only a couple bucks each and don't protrude from the diff like the standard hex bolts do, but instead have a lower-profile head and use an allen socket for r/r. This way you can still get it out after you've beat it up real good on some rocks.
Hmmm that seems like a pretty good idea. Do you know of any disadvantages of going with a low-profile plug like that?
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Jnkml
Jul 6, 2015 01:20 PM
