1" bore MC upgrade question 85 4Runner
Old 02-01-2011, 12:56 PM
85 4runnen4life's Avatar
I have never messed with hard brake lines before so Im trying to be very cautious about this next step.
I found a new 1" bore MC but as you can see the fittings arent positioned the same.
Im wondering if I could just break loose the front line (blue) at both fittings and pivot it CW 90'??? I may have to tweek it slightly but Im just not sure if its a good idea. I already went to the junk yard and looked for a pre bent piece that would work but the yotas in the yards around here are picked CLEAN!
Any info you guys might have to offer a noobie like me on the matter would be greatly appreciated.
Thanks in advance
Old 02-01-2011, 12:59 PM
xxxtreme22r's Avatar
loosen both ends tilt and bend the tube as needed. That's what I did. Just be careful and not make any excessive sharp bends if just using your hands and not a tube bender. You can either break the line or kink it causing fluid flow issues.
Old 02-01-2011, 01:04 PM
NicCantDecide's Avatar
Personally, I'd just go to O'Reilly and get a tube bend/flare tool...they're $20 tops if I remember correctly. New tube is cheap, a crack in an old tube you cranked on isn't.
Old 02-01-2011, 01:26 PM
I guess Ill give it a shot repositioning the old one and if I break it Ill be learning about how to bend and flair break lines
woohoo
Old 02-01-2011, 03:12 PM
thanks xxxtreme22r.! I got er done. I just bent it in by hand. Its frikin amaizing how much better the breaks feel. I could stop a semi trailor now
Old 02-01-2011, 03:18 PM
if you think the pedal is a little too stiff like I did, upgrading that booster to a dual diaphragm will help with that as well. Did you remember to adjust that actuating rod? You might not have had to though, I didn't till I upgraded to the dual diaphragm.
Old 02-01-2011, 04:39 PM
I did not adjust the actuating rod.
I did feel like the pedal was a bit stiff but she stops like crazy now.
What exactly does to two diaphram booster do for the breaking power? The first thing I thought was, why do people upgrade MC and the booster when just the MC upgrade does soooo much.?
Old 02-01-2011, 04:43 PM
the booster allows more power to push the larger MC. It will still brake the same, but the pedal won't be as hard.
Old 02-01-2011, 04:49 PM
thats next on the list then... thanks for your time and info my friends
Old 02-01-2011, 04:58 PM
Pool Playen Bob's Avatar
im glad you made this thread. i was wondering how easy it would be to bend those brake lines. i just scored a booster and a mc out of a 97 T-100 so im pretty pumped on putting that in my runner.
Old 02-02-2011, 07:53 AM
they bend pretty easy, just be super carefull to not make any sharp bends. I used my palm to kinds shape the bend sweep.. good luck.
Old 02-03-2011, 09:27 AM
rattlewagon's Avatar
When bending brake line, I usually go around something like a small diameter pipe or ratchet.. Makes a nice smooth bend
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
87turboPA
07-12-2015 07:49 AM
Quick Reply: 1" bore MC upgrade question 85 4Runner
