Sponsored by: CARiD
rear backing plates/complete axle assembly question
Old Jan 16, 2011 | 02:08 AM
McBrat's Avatar
current axle is from rear of '86 4-runner
potential donor axle is from rear of '90-93 pickup. don't remember the exact year.
can the complete assembly axle shaft to lug nuts be bolted onto my '86 housing?
I searched and searched, and found that the backing plates are different between the axles, but is the bolt pattern where it bolts to the housing the same?
Old Jan 16, 2011 | 06:41 AM
blake.nemitz's Avatar
yea as long as the shafts are the same lenghth, should be a bolt over swap, and i think both those rears are the same ifs width
Old Jan 16, 2011 | 06:48 AM
waskillywabbit's Avatar
86-95 4WD is pretty much the same rear axle with minor differences, all 6 lug 5 on 5.5
:wabbit2:
Old Jan 16, 2011 | 07:16 AM
4Crawler's Avatar
I think the backing plate difference is in the 2nd gen 4Runners with the rear coils. E-brake setup is different as I recall, same parts but different locations. But pickup and 1st gen 4Runner should be very similar.
Old Jan 16, 2011 | 07:23 AM
he should have the same brakes still since he is using the housing only and his old backing plates 4runner brakes on a pickup axle.
Old Jan 16, 2011 | 12:54 PM
McBrat's Avatar
:wabbit2:
my current backing plates, shoes, and ebrake set-up are toast, so I'm looking to just pull the entire assembly from the truck axle into my housing...
just wanted to make sure the 4 bolts that hold it to the housing were the same pattern...
thanks.
GreenLion
Jun 7, 2021 10:49 AM
cchinny
Jun 25, 2015 08:11 PM
Niameyrider
Jun 25, 2015 05:50 AM
TheManOutside
Jun 18, 2015 03:32 PM
