Sponsored by: CARiD
Overheating
Old May 31, 2014 | 08:38 PM
bradc's Avatar
Overheating
I just recently purchased an 1989 toyota 4x4 with 3.0v6 and auto transmission. Right after I purchased it I noticed the temperature gauge was running just a hair past middle point so I had the radiator flushed and a new thermostat put in the truck is still running a little hot but now I notice when I shut it down seems like it gets hotter after about a minute or so it will start gurgleing in the over flow tank. I purged the radiator best I could shouldn't be any air in it. Please kelp its ticking me off..
Old May 31, 2014 | 10:39 PM
rworegon's Avatar
Did you replace the radiator cap too?
Old Jun 1, 2014 | 12:56 PM
bradc's Avatar
no I did not. But when I take the cap off and rev the engine it shoots some water out the top of the radiator.
Old Jun 1, 2014 | 02:18 PM
rworegon's Avatar
This is a normal condition, IMHO, when the rad cap is off.
Old Jun 1, 2014 | 03:51 PM
ZUK's Avatar
ZUK
You just confirmed it....your radiator is 98% clogged up. The flush that you had done is not the solution. NEW radiator time. http://radiator.com
Old Jun 1, 2014 | 04:22 PM
rworegon's Avatar
I dunno Zuk.....my rad, even when brand new, would overflow (bubbles being purged?) but not shoot coolant out with the cap off. His rad could be plugged tho as you suggest. OP, can you clarify what you mean by 'shoots some water out'?
Old Jun 2, 2014 | 05:42 AM
bradc's Avatar
water boils up about 4 inches out of radiator when I rev it. Also I just noticed the radiator cap rubber seal looks like its broke in 2 places im replacing that today.
Old Jun 4, 2014 | 05:34 PM
rworegon's Avatar
bradc, any update?
Old Jun 4, 2014 | 06:27 PM
bradc's Avatar
yes I bought a new radiator cap and it has helped it doesn't get as hot as it did but sometimes it still climbs to about 3/4 temp when i'm sitting and idleing and it doesn't gurgle over to my overflow a minute or two after I shut it off so thats progress. Clutch fan seems ok waterpump doesn't leak nor is there any play in the shaft. Called the radiator shop the will pull the radiator and boil it out for 200.00 or I can by a new radiator 159.99 new radiator is the way I'm going along with all new hoses. for 200 buck i'll have all new stuff.
Old Jun 4, 2014 | 06:40 PM
rworegon's Avatar
Great plan! Oh, and fill the block through the upper radiator hose before attaching it to the radiator.
ladybugRC
458
Aug 21, 2020 10:41 AM
Corvoid
Dec 11, 2015 11:21 AM
alexcarey
Oct 14, 2015 06:05 PM
larrys93pickup
Sep 17, 2015 07:05 PM
LotOMiles
Sep 14, 2015 11:45 PM
