Options for lifting 92 4runner to fit 33's
Old 08-24-2006, 06:56 AM
nineball's Avatar
I want to stay away from body lifts if possible, I was told I could crank the t-bars and add some rear coil spacers and fit them with the right wheels but I want some more opinions if you have them....
Old 08-24-2006, 07:57 AM
slosurfer's Avatar
You can fit 33x10.5's with no lift. 33x12.5's will require a lift and aftermarket wheels with less backspacing. Bj spacers will give you enough lift in the front and there are a ton of choices for aftermarket coils in the rear. Try the yellow search button and I am sure you will find way too much stuff to read.
Old 08-24-2006, 06:50 PM
tc
tc's Avatar
x2 buy some 33x10.50, mount them on the stock rims and off you go. All the ground traction and clearance, with none of the fitment issues.
Old 08-25-2006, 11:39 AM
4Crawler's Avatar
Here are some recipies:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old 08-25-2006, 02:39 PM
Sonofmayhem's Avatar
Im going w/ bj spacers, new torsion bars, new leaf springs and shocks AND a 1in bodylift on my 89. HOPEFULLY this will help keep the COG low, but give me clearance.
Old 10-11-2011, 10:46 PM
JoeOnTheGo717's Avatar
I have a 98 Tacoma, 3" suspension lift, spacer in the front. I should fit 33x10.50's right? if anything do the pinch weld with a hammer, but no sawing?
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
skoti89
07-06-2015 07:45 PM
wilbertd
07-06-2015 07:39 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Options for lifting 92 4runner to fit 33's
