Sponsored by: CARiD
1988 22re fuel problem
Old Oct 12, 2007 | 05:28 PM
stormy76's Avatar
new guy here. am repairing my daughters 1988 Toy pu., w/22re. started with a blown head gasket, & warped head. Kid's!!!!! After replacing with a new head, I now have no fuel pressure. Am getting no power to fuel pump, did bypass at DLC1, still nothing. are there any fuseable links in the wiring?, also where will I find the EFI main relay? can't find a fuse for the pump itself & all the other fuses checkout OK. I'm lost & could use some help!!!!!
Thanks, Stormy76
Old Oct 13, 2007 | 04:22 AM
xsvtoyz's Avatar
I found this I don't know if it will help but here's a link anyway
https://www.yotatech.com/forums/f116...umbers-102344/
Old Oct 13, 2007 | 09:26 AM
4Crawler's Avatar
Here is the wiring diagram for the pump:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Oct 13, 2007 | 11:19 AM
stormy76's Avatar
thanks for the info, but what i really need to know, is the location of the relays in the vehicle. found the EFI relay in engine compartment,& swapped it into another truck & it checks out, but have no idea where circut opening relay is. will check out air flow meter also. when i jump the fuel pump test connector, i get nothing.powered the fuel pump, & it works. Bear with me, I'm an old school shade tree wrench, & all these relays & sensors are confusing. thanks, stormy76
Old Oct 13, 2007 | 12:04 PM
4Crawler's Avatar
Read the page I posted a link top above. It has that information:
- http://www.4crawler.com/4x4/CheapTri...ORelayLocation
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Jumper is either here:
or here:
Old Oct 14, 2007 | 07:49 PM
stormy76's Avatar
thanks for the links to that info, was very usefull.
stormy76
Old Oct 12, 2011 | 10:16 AM
confussed's Avatar
Angry
1985 toyota pickup 2 w/d no turbo auto 22RE ran that morning put a radio and amp. in and blew the radio now it will turn over but not start new fuel pump, computer, iginter,coil, pressure ragulator, distrubutor, throttle body sensor, air flow mass, im getting spark HELP LOL CHECKED ALL FUSES AND LINKS GOOD
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
karbin
Jul 5, 2015 11:37 PM
