Sponsored by: CARiD
Options for lifting 92 4runner to fit 33's
Old Aug 24, 2006 | 06:56 AM
nineball's Avatar
I want to stay away from body lifts if possible, I was told I could crank the t-bars and add some rear coil spacers and fit them with the right wheels but I want some more opinions if you have them....
Old Aug 24, 2006 | 07:57 AM
slosurfer's Avatar
You can fit 33x10.5's with no lift. 33x12.5's will require a lift and aftermarket wheels with less backspacing. Bj spacers will give you enough lift in the front and there are a ton of choices for aftermarket coils in the rear. Try the yellow search button and I am sure you will find way too much stuff to read.
Old Aug 24, 2006 | 06:50 PM
tc's Avatar
tc
x2 buy some 33x10.50, mount them on the stock rims and off you go. All the ground traction and clearance, with none of the fitment issues.
Old Aug 25, 2006 | 11:39 AM
4Crawler's Avatar
Here are some recipies:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Aug 25, 2006 | 02:39 PM
Sonofmayhem's Avatar
Im going w/ bj spacers, new torsion bars, new leaf springs and shocks AND a 1in bodylift on my 89. HOPEFULLY this will help keep the COG low, but give me clearance.
Old Oct 11, 2011 | 10:46 PM
JoeOnTheGo717's Avatar
I have a 98 Tacoma, 3" suspension lift, spacer in the front. I should fit 33x10.50's right? if anything do the pinch weld with a hammer, but no sawing?
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
wilbertd
Jul 6, 2015 07:39 AM
Vargntucson
Jul 4, 2015 12:15 PM
